Question about Magicard Office Equipment & Supplies
Error 24:24 printer doesn't work anymore. It says general error. Plase contact magicard technical support quoting code 24:24
The Machine
  • 788 Answers
SOURCE: ricoh error code sc291
There's a list of Ricoh error codes right here: http://www.tecnodigitale.com/riparazioni/pdf/Codici_errore_Ricoh.pdf but it doesn't indicate an sc291 for the 3800 or for any other model for that matter.
There are usually contacts on the cartridge that interface with a reader in the printer to detect the chip in the cartridge. Examine a cartridge and look for any electrical contacts, make sure they don't look damaged or dirty clean them with 98% isopropyl alcohol. With the printer powered off and upplugged, try to find the corresponding contacts inside the printer for each of the contacts on the cartridge, clean those too.
If that doesn't change, try a different cyan cartridge, if that still doesn't work you will probably have to get the machine serviced.
Posted on Jan 14, 2008
SOURCE: epson R300 "GENERAL ERROR SEE YOUR PRINTER DOCUMENTATION FOR INFORMATION ABOUT CLEARING THE ERROR".
in my r300 epson printer general error appear . How can i remove or clear this error from my printer lcd
Posted on Apr 27, 2009
  • 5 Answers
SOURCE: first time I turned the power on the machine said "Warning system error S0001"
The cause is the lock lever of scanner unit is locked. Lift the scanner lid and unlock the scanner unit with the switch located under the lid on the left side.
Posted on Jun 03, 2009
SOURCE: general error see printer documentation for
same here as well! waiting for a response
Posted on Jul 30, 2009
komguy
  • 2306 Answers
SOURCE: 59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Posted on Aug 20, 2009
Error code 24:08
Hi There,
The most common reason for General Error 24:08;
Hand Feed Mode is ON. (only time this error is shown)
The printer expects the card to be fed from the manual card feed slot at the front of the printer.
If the card is 'manually' fed from the rear of the printer (with the rear card hopper removed), then this error message will be displayed.
Hope this helps,
Kind Regards,
MC.
May 06, 2014 | Magicard Office Equipment & Supplies
Error code 24:06 magicard
Hi There,
General Error 24:06 may indicate a problem with the front card sensor (very rare though). Open the lid, remove the dye film. Check that there are no cards jammed near the front of the printer (just before the flipper unit).
Try unplugging the printer. Cancel all print jobs if any are pending.
Plug in the printer. Once initialised, open the lid, run through the cleaning sequence (a Magicard cleaning kit - 3633-0053 is required). If the problem persists even after cleaning, contact your Magicard dealer. The warranty status can be checked here;
http://www.magicardonline.net
Enter the serial number of your printer in the QuickSearch box (Menu -> Info -> Serial Number)
Hope this helps,
MC.
Apr 14, 2014 | Magicard Rio Card Printer
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
I have a Magicard Rio I keep getting the error message card jam error 02:12 yet there is no card jam if i put a card in the back it ejects it correctly help
Hello Colin,
I'm not sure how old your printer is, but I suspect this is caused by a loose connection on the front card sensor (especially if the error occurs when initialising). If there is a loose connection, the card sensor always shows as blocked (hence the error 02:12). I guess this is a Rio 2e and not a Rio 2 model.
Send us an email to;
support@magicard.com
Make sure you quote the printer's serial number in the email.
I can send you some detailed instructions for confirming this is the problem, and also suggestions for repairing the printer.
Regards,
MC.
Nov 16, 2012 | Magicard Rio ID 2 Card Printer
Rio pro error code 24:04
Hi Magicard Rio Pro message:
"General Error : Contact technical support, quoting error 24:04".
Somebody help me?
Jun 28, 2012 | Magicard Rio ID 2 Card Printer
Card jam please clear printer
Hi Imran,
I realise you probably resolved this issue a long time ago, but this may help others with the same problem (Card Jam on Rio Pro / Enduro / Enduro+).
Immediately after the Card Jam - Please clear printer mechanism, there should be an error number. All card jam errors begin with 06:??. Most common would be Card Jam 06:05.
This error means that the rear card sensor has detected a card.
However, the card has not past through the sensor. This could indicate a failed card sensor (always on). This may sometimes be caused by static on the cards.
To confirm this, switch to 'Hand Feed Mode' (on the front panel: Menu -> Hand Feed Mode -> ON). Cards are then fed (when requested) from the hand-feed slot on the front of the printer. If the error changes from Card Jam 06:05, to General Error 24:08, this would suggest a faulty rear card sensor (very rare).
Try leaving the printer switched off, and with the DC power disconnected for a few hours. If the problem persists, you should contact Magicard Technical Support.
With Best Regards,
MC.
Apr 09, 2012 | Magicard Rio Card Printer
Error code 24:03 magicard- card was stuck in machine
Hi There,
General Error 24:03;
This error is caused by a faulty RFID tag in the colour dye film.
Contact your Magicard dealer for a replacement dye film.
Sep 06, 2011 | Magicard Rio Card Printer
Getting it ready for printing
Hi There,
There is no need to set the ribbon tight. This will be re-initialised each time the lid is closed or the printer boots from being switched on.
The error message and number is important. Depending on which driver you have installed, you may not see the error message on the status monitor. However you need to know what the error is, and most importantly, the error code (04:??).
To see what the error is follow these instructions;
Switch on the printer and let it try to initialise. When it errors and the Red LED is flashing,
Download and install the Magicard Support Utility (V3.14).
You can get this here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=9&supportOption=3
Run the Magicard Support Utility. Select 'USB' for the comms port. When the other tabs open up, select 'Query Printer'. Click the 'Query' button. The left-hand pane will display the result of the query.
About a third of the way down is the 'Last Error Reported' line.
What is the last reported error (and crucially the error number)?
From this I should be able to tell you what to check.
Also, have a look at the following;
Enter your printer's serial number in the QuickSearch box.
You will see the printer's current warranty status as well as all the latest driver / firmware downloads and more.
Magicard will still offer you lots of support whether the printer is in or out of warranty.
With Best Regards,
MC.
Sep 05, 2008 | Magicard Avalon Duo Thermal Card Printer
I have error whenever i just select encoding only
Hi There, I presume (from the error number) that you are using LC3 (monochrome) dye film in your printer. This error is normally given when the printer detects LC3 (monochrome) dye film, but is then sent 'Colour' printing data from the driver. If you have 'encode only' selected there should be no printing data sent to the printer at all (number of copies = 0), only the mag stripe information should be sent. I suggest you contact Magicard Technical Support in the UK (I am one of their support engineers). We will need some further information (serial number of the printer, etc). Please also check you have the latest firmware (print the internal test card by pushing the button on the back) and are using the latest driver. All are available for download from: www.magicard.com To contact customer support send an email to: customer_service@ultra.co.uk Advice is free regardless of whether the printer is in warranty or not. With Best Regards, Alan.
Aug 20, 2007 | Magicard Avalon Card Printer
324 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
