Whenever i want 2 login,it will tell me application error
It keep telling me "YOUR
I couldn't see if someone else has already posted a solution. This same error message happens to us all the time-usually after a power failure, or windows decides to reboot the computer...In any case it will be necessary to login to "user magnager"..Once in switch to the tab that says "login"...then where it says "application" use the pull down menu to "icverfiy for window"
Then select any user that is listed , then go to the bottom of the page and select "log off user"...Close the program and start Icverify again...should be good to go
Feb 11, 2011 | Ic Verify Payment Processing Software -...
Hi am aneesh from india ... when i login into
Aneesh,
It seems your Yahoo messenger not installed correctly. Please unintsll and reinstall.
WIth regards
FIXYA team
Sep 28, 2010 | Yahoo Messenger
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Jun 10, 2010 | Dell Dimension 4400 PC Desktop
Whenever i open application i get error as the application failed to initialize properly 0xc000007b
Your Pc might be infected with virus or malware. Do a scan on both and remove the 'dangerous objhects'
May 20, 2010 | Computers & Internet
Cmd.exe application error
Check out the below link to know the error -
http://hubpages.com/hub/cmd-exe-application-error
post further comment for more help..
Good Luck!!
Thanks
Jul 19, 2009 | Acer Computers & Internet
Whenever I go Shopping on homeshop18.com and
this sounds to be a java runtime issue. make sure to update or install java runtime enviorment http://www.java.com/en/download/index.jsp
Feb 23, 2009 | Microsoft Windows Vista Ultimate Edition
Whenever I start my system I first get an alert before login of profile as "crmgoldbpe.exe - Common Language Runtime Debugging Services Application has generated an exception that could not be handled....
click start -> run. Type msconfig hit enter. Goto the startup tab and look for anything containing crmgoldbpe.exe and uncheck the box next to it. Restart your computer. The error should be gone. This is part of a spyware program so you should also run an anti-spyware program such as spybot search and destroy from www.safer-networking.org.
Dec 19, 2008 | Microsoft Windows XP Professional
Samsung SGH-J210 Java app download error
This error may be because of
1. the JAR file size limit on your cellphone.
2. the file itself is corrupt.
3. the file has install site locked. (some java games can only be downloaded and installed from a particular site)
Nov 19, 2008 | Samsung SYNC SGH-A707 Cellular Phone
W850i Application/Games not opening
Actually, just got my back today from repair. Called Sony ericsson about the problem and they told me to send it in for repair. 'Cause it's under warranty (Which I wasn't asked if it was) I also went ahead and asked about the broken keypad. it took less than two weeks. Had to use my old s710. So far I have not been able to find a solution. Maybe flashing the phone could help. I think that's what they did. Because it looks like it came from SE instead of Att.
Mar 31, 2008 | Sony Ericsson W850i Cellular Phone
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
