Question about Panasonic Televison & Video
A small cut in the cord and would no work. If you straiten the cord the power reaches the tv. however, on the second time straitening the cord the cord let out a bang and a large spark. Now the tv will no work. How can i fix without buying a new tv??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
You would have to know a little about electrical repairs, if you don't then I suggest finding someone who does because the repair can present electrical dangers.
Some might say to splice the cable around the cut, but I'm not one of them. If the power wire comes from the inside of the TV then you can usually open up the back of the TV and replace the wire with a little soldering. Make sure the wire you use is properly rated for a standard house appliances. (lamp/etc.) If the wire instead simply plugs into the back of the TV then you may just have to contact the manufacturer (or electronics store) to get a replacement wire.
Posted on Jan 03, 2014
4 Suggested Answers
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
  • 8457 Answers
SOURCE: switch on the iron infront of the TV and a large
Now tv turn on,u still have power and LED power light indication flashes?Yes this tv is repairable the tv power supply board is the causes and problems,that the board where the power a/c cord plug into it,can u take things aparts and putting it back again?Try website like Ebay.com to buy a refurbish power supply board for the replacememt.
Posted on Jan 31, 2011
spr1949
  • 1182 Answers
SOURCE: Lg 42 plasma - loud bang/spark smelly smoke and small flame inside.
It is a short circuit caused by some components and/or power capacitors. This may need assessment by a qualified service technician.
Posted on Jul 31, 2012
My Nissan Micra is suttering round comers when accelerating what do I do. Anything I need to check other than the full oil tank?
You may have a low Transmission fluid level. As you turn a corner you tend to lose power but gain power as the car straitens out again
Dec 30, 2015 | Nissan Cars & Trucks
Syma S107 Mini helicopter won't take up. Only stays on the ground ever after full charge. Everything seems to work but won't go airboune
once again how old is it? when was the last time you checked the controller batteries? how are the rotors pitched? are they capable of changing pitch? are they bent from crashing and straitening?
Lastly check the controller for proper function.
Dec 31, 2014 | Toys
Cd changer stuck
There is a small pin hole on the door of most changers. straiten a paper clip insert in the hole ratchet back and forth on the gear in side to open.
Sep 21, 2014 | 2004 Nissan Murano
My tablet isnt charging at all
Look at the port that you plug the wire into on the tablet. There should be a connector in the middle of it sticking straight out. If the connector is bent, try to carefully straiten it.
If that's not the problem, try using a different cord to charge it. Sometimes the cords go bad.
If neither of those work, your tablet might be broken. Take it back to where it was purchased and see what they can do for you
Mar 03, 2014 | Irulu Tablets & eReaders
Lite On LVW 5005 tray will not open
Drives stick from time to time. Get a Paper Clip and straiten one end out. Look for the small hole on the front panel. Stick the clip end into the hole and push. The tray should open. Grab the tray and move it rapidly in and out seven or more times. This may stop the tray from sticking, and if not you know how to open it manually.
Dec 31, 2013 | Lite On Computers & Internet
Cant open cd drawer
most cd players have a small hole in front under the drawer, with the power off, you need a paper clip and straiten it, slowly slide it in the hole until it bottoms out, once it bottoms out you need to push it slowly until the drawer starts to open, mind you it wont open all the way so you will have to open it the rest of the way manually.
Jun 06, 2011 | Audio Players & Recorders
The drive wont open
in the door area, look for a small hole. straiten out a paper clip and insert into the hole. push it and the door should open
Jan 14, 2011 | Gear Head ( 20XDVDTFEXT) External DVD...
Cheapest easiest way to remove a factory stereo from 2004 astra?
coat hanger straiten and cut to 4 peices and put in holes, push outwards and pull at the same time and it should work
Apr 21, 2010 | Car Audio & Video
I have a govideo dvd recorder model #r6740 and
Straiten a paper clip, find small hole in front of cd face. Push paper clip in, It should release the tray.
Dec 29, 2009 | GoVideo R6740 DVD Recorder
Game does not play
No lights come on?, try another power cord and make sure the memory pak is inserted correctly and has not come loose, the memory pak is actually ram, if it's not getting a good connection then nothing's gonna work
May 10, 2007 | Nintendo 64 Console
Televison & Video Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
