Question about Krups Coffee Makers & Espresso Machines
Water leaking krups xn 3008 - Krups Coffee Makers & Espresso Machines
3 Suggested Answers
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
  • 3799 Answers
SOURCE: where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Posted on Feb 24, 2012
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Nespresso xn 2003 - water comes through without a capsule but when a capsule is in place the water goes straight into the catch tray?
at the back of the capsule holder there is a metal that correspond
with the sensor sow your problem is the sensor is not finding the capsule holder at the and of the capsule holder do you see the magnit if not replace and try agian
Jul 08, 2014 | Krups Coffee Makers & Espresso Machines
How do I increase water temperature on Krups KP 2100
Heat the cup before you use it, run hot water over it, or boiling water. The machine does not make very hot coffee otherwise.
Sep 22, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
There is no power in my krups xn 2000 nespresso maker . had it open and measured points from end of the cable and the control board looks good anyone know if there is something else i can do many thanks
Frequently the power button / power switch seems to be broken. Apparently a tiny film of grease builds up between the conductive material in the rubber button and the IC board.
See this video on youtube how to open it up and remove the dirt. I repaired my machine this way, takes 15 minutes, and I was surprised how only a thin film of grease could cause the malfunctioning of the button.
Feb 09, 2010 | Krups Coffee Makers & Espresso Machines
Krups kp 2000 water leak
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Xn 85 fouling spark plugs
check the compression on #1 and possibly a leaky #1 injector. What fouling, I'm guessing carbon(black plug). If it's oil you will need to do a leak down compression check this will tell you if it's rings or valves. If you suspect a leaky injector (as I do) swap it with #4 (30 min job) and see if #4 plug becomes fouled
Nov 20, 2008 | 1985 Suzuki XN 85 Turbo
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
