Question about Dodge caliber camshaft. engine. . camshaft & valves erh 4.0l
Ep 21 camshaft with green paint out of 351 clevo what type of cam is it
How do I align the timing marks on crank, cam and injector pump on a Mazda 2.5td
Would need to see type of engine and a good look ,does it have any marks on front of engine ? if not then crank mark will be through a hole in bellhousing ,injector pump if common rail will have no marks as not needed to be timed in ,camshaft if no holie in spoke on gearwheel tand no mark on rim then remove the rocker cover and look on back of camshaft for a slot ?but no year mentioned here so ?? why didnt you put some white paint marks on gears before you took it apart
Jun 30, 2016 | Mazda Cars & Trucks
Whst is code PO340
bad news
those is the main /cam sensor
if fail hard, engine stalls, no spark
which engine, 4.0liters?
wrangle TJ
chapter 21 (dtc pages)
cam single dead or dropping out 1 to 10 times
it does give early warnings. (can)
check wires to it.
chapter 8d
free fsm TJ
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Jan 16, 2016 | 1999 Jeep Grand Cherokee
I need to know wich key way to use when installing the timeing gears onto the camshafts on a 1989 mazda mpv 4.0 liter v-6
do it by appliance of science ,TDC no1 then exhaust and inlet valves on the back of the cam so they closed ,now some vehicles have a paint mark on the inlet and exhaust marks on the gearwheel well these paint marks line up so exhaust cam wheel it says inlet so this p?ints to inlet cam wheel and the inlet cam wheel that says exhaust points to exhaust (twin cam per head ) have a play and if you cannot do it then post and i will answer tomorrow as i have a date tonight
Sep 21, 2010 | 1989 Mazda MPV
INSTALLED A KNEW TIMING BELT ON MY 2003 HYUNDIA ELANTRA GLS WITH A 2.0 ENG.NEED TO KNOW WHERE ARE THE MARKES FOR THE CAM
On the top two camshafts you gonna have to look for a paint mark on the wheel where the theeth are. its a litlle tinny dot of paint. then look at the other one and find the mark. clean the camshafts first with some wd 40 or some gas but be careful not to clean the marks off. when you find the dots rotate each camshaft until the left one's mark is at 3 pm ( looking at a clock) and the right camshaft's mark is at 9 Pm (both of the marks will be next to each other) MARK--- ----Mark now the bottom crankshaft. rotate it until the timing mark that's on it (or notch) is alligned with the nimber 0 thats on the timing cover Good luck
Nov 29, 2009 | Hyundai Motor 2003 Sonata
Can u send me driver robo-351 web cam at my id
Here is a link to download the robo-351 install driver. After downloading, you will just have to rename to ".exe" instead of .ps http://dennisalbert0.tripod.com/Knopfler/robo351.ps
Oct 14, 2009 | Micro Innovations MCNIC50C Webcam
Need torque settings for tappets and cam
CAMSHAFT BEARING CAP BOLTS 19 TO 21,CAMSHAFT SPROCKET BOLT 90,
Mar 06, 2009 | 1992 Mitsubishi Montero
2004 Durango 5.7 timing gear alignment
  1. If tensioner assembly is being replaced, install tensioner and mounting bolts. Torque bolts to 28 Nm (250 in. lbs.) .
  2. Retract tensioner if required. CAUTION: The camshaft pin and the slot in the cam sprocket must be clocked at 12:00. The crankshaft keyway must be clocked at 2:00. The crankshaft sprocket must be installed so that the dots and or paint marking is at 6:00.
  3. Place both camshaft sprocket and crankshaft sprocket on the bench with timing marks on exact imaginary center line through both camshaft and crankshaft bores.
CAUTION: The timing chain must be installed with the single plated link aligned with the dot and or paint marking on the camshaft sprocket. The crankshaft sprocket is aligned with the dot and or paint marking on the sprocket between two plated timing chain links.
Feb 13, 2009 | 2004 Dodge Durango
I cam robo 351 driver 4 free
I have found driver files for ROBO-351 usb camera, Please follow the below linl. Select category as camera and model I-ball Robo-351. Download both zip and rar files. Unzip the zip file and you will find setup.exe file. Connect camera and run setup. Your camera will work.
http://www.iball.co.in/Download.aspx
Thks & Regards
May 17, 2008 | Cameras
Dodge caliber camshaft. engine. . camshaft & valves erh 4.0l Logo
Top Mopar Performance Vehicle Parts & Accessories Experts
Timllfixit
unosuave
Are you a Mopar Performance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
