Question about LG WD-80130F 7.2kg Washing machine
Parts diagram softener tray not draining c
2 Suggested Answers
TheMazz
  • 78 Answers
SOURCE: how do i get the detergent/fab. softener tray
Softener is a combination of wax, transport solution, and perfume.
What clogs up the dispenser is the wax.
Try pouring very hot water (close to boiling) down the path that the softener takes to get to the tub. This will melt the wax build up and wash it out.
You will need to do this multiple times to get all the wax melted.
Don't use water so hot that it melts the plastic parts.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
My Washing machine hotpoint aquarius WDPG 8640 will not take in fabric softener
It is likely that the tray need removed from the machine and the back side of the drain cleaned. Over time the softener can build up and eventually plug off from the back side. So just cleaning the tray won't clear the problem.
Jun 21, 2016 | Hotpoint Washing Machines
How do I get water out of fabric softener cup
This is normal to have left over standing water in the softener dispenser cup. That being said, some units can have more standing water than others because the machine isn't level (try leveling the unit).
Note: Softener is a "wax" and can clog up the water inlet openings. You can remove the whole dispenser assembly by pulling all the way out and depressing a button while pulling on dispenser tray. (button located middle-back)
For future parts or diagrams visit us here. Appliance Parts
Feb 05, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener drains out, but pumps water back into dispenser after draining?
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Softener reservoir doesn't drain when washing. Kenmore Elite about one and a half years old.
Possible blocking on the drain from the tray, remove the accumulated softener from the dispenser , clean and check the drain line. It can be blocked with residue or dirt.
Mar 17, 2013 | Washing Machines
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
Jun 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Softener tray filling with water
open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
Sep 23, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch Classixx 1000: Won't drain
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
