How to remove a radio in a 2000 ae112 r corolla
Radio removal
SOURCE: Remove the radio from 1997 Toyota Corolla
i have a 97 corolla as well, and i've changed the radio out several times on my own. if you take a small screwdriver and stick it in between the panel that goes around the around the area where the radio is, u should be able to pry it off relatively easy. just be sure to remove the sliders off the AC controls before you do. after you pop that panel off, you just have to disconnect the wiring harnesses going to the clock, hazard lights, rear defroster, and AC button. the radio is bolted in there with a mounting bracket, so you'll have to unscrew that as well. you'll need to unscrew that bracket from the radio you have in there, and mount it to the one you wanna install....hopefully this helps you out. it sounds harder than it really is.
Posted on Sep 17, 2008
SOURCE: car radio removal
This isn't hard, you just need to breath deeply and take courage.
Be aware that the centre moulding where the radio is extends ove the steering wheel and the whole thing needs to come out. There are screws under the switches that release this panel and the panel under the wheel. Remove them all. Note the cables for the instrument lights and speaker.
Note the grommet around the ignition switch. You have to work this with a screwdriver so the top panel can come forward. This grommet will pull off but I bet you can't do it before the panel comes off. Do it before you put it back.
The panel is click-fit into the centre console. You can lever it off with a paint scraper. Note the lighter wiring.
Once the panel is off the radio is held in by 4xcrosshead screws, just looking at you.
Needless to say, the brackets are exclusively Toyota and fitting a new third party radio is not so easy. Your best bet for a replacement is a good one out of a wreck of the same vintage. It will go straight in and plug up. I got a Camry one. It has security coding but fortunately it was never activated. If the radio is coded make sure you get the full details and provenance. You may need to get it reset by the dealer.
Good luck
Posted on Mar 02, 2009
  • 12 Answers
SOURCE: need instructions on how to remove my 2005 toyota corolla radio
Tools required: Phillips screwdriver, small flatblade screwdriver, rachet with 6 inch extension & 10mm socket.
1. Remove negative battery terminal (for stray voltage & airbags.)
2. Remove gear shift trim
3. Remove cable attached to lighter socket.
4. Remove center climate control knob and screw beneath it.
5. Gently pry both bottom corners of climate control face (up then towards the rear) until clear of lock.
6. Pull entire climate control console rearward until clips release. Leave all wiring attached.
7. Remove 4 bolts under radio (10mm.)
8. Gently pry between dash and AC ducting panel (both sides) and pull out.
9. 4 clip hold radio to ducting panel, gently pry while pulling radio out the back.
The rest should be easy...
9. 4 clips hols radio to
Posted on Aug 15, 2009
dancandoit
  • 436 Answers
SOURCE: how do i remove the car radio from a kia carnival
The plastic trim all round the radio and heater controls should just unclip, then the raio will be held in with 4 screws.
Posted on Dec 04, 2009
bbbman78
  • 680 Answers
SOURCE: Remove the radio in a ford windstar 2000
There is a ford radio removal tool. It looks like a pair of horse shoes most times. Or you can insert four 8 common D finish nails in the four holes (or 4 six D finish nails) -one in each hole until you feel it click. Be gentile. simultaneously push each side towards their respective front door and gently pull the radio out.
Posted on Feb 21, 2010
Toyota corolla vibration
run fault codes and look for injector misfiring or plug coil problems
Oct 24, 2013 | Cars & Trucks
Timing belt diagram for toyota corolla 2000 ae112
easiest way to change a timing belt is to
first slightly slacken off the belt tensioner
carefully cut the old belt in half along its entire length while it is still on the engine.
remove the outer half only.
place the new belt on the pulleys up against the inner half of the old belt.
cut and remove the inner half of the old belt.
push the new belt fully into place.
re tension the belt as specified.
Feb 20, 2011 | 2000 Toyota Corolla
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
Dec 05, 2010 | 1990 Toyota Corolla
How to remove radio from 1990 cs corolla
I understand you remove the panel and then for a
1990, it has a handle and you simply pull it straight out.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. CAUTION
    On models with an airbag, wait at least 90 seconds from the time that the ignition switch is turned to the LOCK position and the battery is disconnected before performing any further work.
  2. Remove the attaching screws from the trim panel.
  3. Remove the trim panel, being careful of the concealed spring clips behind the panel. Remove the trim panel surrounding the stereo 88276p31.jpg
  4. Disconnect the wiring from the switches if so equipped mounted in the trim panel.
  5. Remove the mounting screws from the radio. Remove the four radio retaining screws and pull the unit from the dash 88276p32.jpg
  6. Remove the radio from the dash until the wiring connectors are exposed.
  7. Disconnect the electrical connectors and the antenna cable from the body of the radio and remove the radio from the car. To install:
  8. Reconnect all the wiring and antenna cable first, then place the radio in position within the dash.
  9. Install the attaching screws.
  10. Reconnect the wiring harnesses to the switches if so equipped in the trim panel and make sure the switches if so equipped are secure in the panel.
  11. Install the trim panel (make sure all the spring clips engage) and install the screws. Conmnect the negative battery cable.
  12. Check radio system for proper operation.
Jul 22, 2010 | 1990 Toyota Corolla
Radio removal in 2006 toyota corolla s
This process is better explained here.
If you are installing a new radio, email me for wire colors.
xxsodasipperxx@yahoo.com
http://www.neocarz.com/blog/2007/07/2006-toyota-corolla-radio.html
Dec 15, 2009 | 2006 Toyota Corolla
How 2 remove d radio from 2000 corolla to install a cd player
you will ned some accessories to put it in properly.
1. 99-3413 metra install braket. will ease the mounting.
2. 70-1761 metra wire kit will allow you to fly through the hookup.
you will be able to get these parts at your local stereo install shop.
when you purchase the mounting kit the instructions on how to remove and reinstall your cd player will be in the instructions. illistrations and all.
Aug 28, 2009 | AviStart 5303 2-Way Security / Remote...
I BUY A NEW RADIO FOR MY TOYOTA COROLLA 2008, BUT I DONT KNOW HAW TO TAKE OUT THE FACTORY RADIO, YOU KNOW HOW?
remove plate around radio.. there are screws where the coin holder is and clips all around are weak.. be careful... after that there will be mounting screws to remove
Jul 09, 2009 | 2008 Toyota Corolla
Need instructions on how to remove my 2005 toyota corolla radio
Mar 19, 2009 | 2005 Toyota Corolla
Aug 22, 2008 | 1997 Toyota Corolla
Computers & Internet Logo
David Payne
David Payne
