Question about 1998-1999 Dodge Ram 1500 Truck 4WD Front Wheel Bearing & Hub Assemb
Heater in dodge pickup not heating properly - 1998-1999 Dodge Ram 1500 Truck 4WD Front Wheel Bearing & Hub Assemb
    Genius:
  • 1A Auto Parts Master
  • 2,494 Answers
Could be blockage in the hoses faulty tap blocked core or baffle in the heater core fallen off.
Posted on Mar 17, 2016
2003 dodge ram 1500......no heat
Does your heater motor run when you turn speed dial ? Have you checked the two hoses that run from the engine compartment to the heater core ? When car is at operating temperature, carefully touch both hoses which should be warm or hot. If only one if hot, then you may have a bad actuator. If both are hot, you may have a clogged heater core or none functioning heater motor. or resister.
If motor is not working, check fuses, if good, then check for power at the switch and then at the heater motor.
Dec 17, 2016 | 2003 Dodge Ram Pickup 1500
Why wont my heater system on my 1999 dodge pickup blow heat out of the vents?
Fan not working or you would feel cool air if heater door was working. Can you hear the fan?
Feb 24, 2015 | Dodge Cars & Trucks
I have a 01 dodge ram pickup the heater doesn't work in both hoses to the heater core r hot a brand new radiator and thermastat put it and the heater blend door was broke so I have function to move the...
Do you have heat when you rev it up? You could have a blocked/clogged heater core. Try back flushing the heater core in both directions to try and clear any deposits. Also if there has been any kind of stop leak added it can clog heater cores right up. Also verify that temp blend door stays in proper position.
Dec 11, 2014 | Cars & Trucks
I have no heat inside my cab on a 2003 dodge ram 2500. heater core is not blocked
either you have a bad thermostat or you have a air lock in your heater hoses remember your heater is fed by the hose by the upper rad hose return is the hose going to the water pump, to bleed the air out fill rad leave the rad cap off start engine run for 5 min. the check the coolant level,fill to top of neck replace rad cap tight, K-D tools make a special funnel to solve this air lock problem
Aug 09, 2014 | 2003 Dodge Ram Pickup 2500
I have a 2003 dodge ram 2500 and i replaced the recir. door and the upper blend door and i still have very little heat inside. the heater core is clear, not cloged
check that the heater control is working and allowing water through the heater . Check that there is not an air lock in the cooling system that is preventing coolant flowing through the system.
1997 dodge pickup with 318 engine
look for cable misadjust of heater mixed door under dash
Oct 10, 2013 | Dodge Pickup Cars & Trucks
I asked the question..."I have a 2003 dodge ram 1500 4x4 with the 4.7L engine. The check eng light is on. obd2 reads code P 0038 And says HO2S Heater Control Circuit High (Bank 1, Sensor 2). the heater is...
P0038=HO2S Heater Control Circuit High Bank 1 Sensor 2,
The oxygen sensors on your truck have an extra wire to them,they are a heated oxygen sensor,
the computer sees a problem with the heated oxygen sensor on the drivers side,before converter.
not the sensor after converter!
Jan 08, 2010 | 2008 Dodge Ram Pickup 1500
I have a 2002 dodge ram 1500 pickup w. hwat issues
is this a problem w/ the interior vents? maybe stuck venting in outside air rather than from the heater box? did the heat only stop working after the radiator/hose install? if so, then you probably have a big air pocket stuck in the heater core.
Sep 30, 2009 | 2002 Dodge Ram Maxi
No heat
You probably just need to backflush your heater core. You can use a hose to flush it back and then forward. You'll be surprised at how much sludge and gunk will come out.
Jan 21, 2009 | 2004 Dodge Ram 1500
1998-1999 Dodge Ram 1500 Truck 4WD Front Wheel Bearing & Hub Assemb Logo
27 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
