If i turn off hot water at wall ,washer will not run though its cycle
  • 3,961 Answers
This indicates the cold water inlet valve has failed in the closed position. It is an electrically operated "solenoid" valve, and failure is a common problem. With that the washer is getting only hot water.
Call a service tech if you are unsure how to remove the control panel to expose this valve and its connections.
Posted on Jan 03, 2014
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
docjohn174
  • 943 Answers
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    SOURCE: Whirlpool Model LSV6234AWO
    door switch bad?
    Posted on Oct 18, 2008
    SOURCE: Boiling water in Miele automatic W750
    Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
    Posted on Jan 09, 2009
    My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
    The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
    Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Machine starts to fill then stops and beeps
    try it on rinse cycle if goes ok then the hot water valve is faulty
    Dec 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
    Frigidaire lws3312d washer not filling up
    check the water faucets on the wall and make sure that both hot and cold are completely open.
    check the water inlet hoses for any kinks or leaks.
    Nov 05, 2008 | Frigidaire CWS3600AS Top Load Washer
    Water in my washing machine
    it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
    Note: unplugging the machine will not stop the water from running
    May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
    Regards Faggly
    Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    Whirlpool LHW0050PQ - Water wont empty or fill
    This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
    Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
    Washing Machines Logo
    14 people viewed this question
    Top Washing Machines Experts
