Question about Chrysler 2007 Sebring Touring
Engine knock Single female not wanting to get ripped off looking for insight please. My 2007 Sebring started making pinging/knocking sound when turning car on. Then eventually started getting louder on acceleration & losing power. Oil change less than 3 wks ago. & no check engine light on. Got so bad had to pull over. I opened the hood; no burning smell, no oil or other fluid leaks showng, belts looked fine, not the fuel pump but down a quart of oil! Just had oil change 2 weeks ago! Towed to mechanic. Is this a plug, lifter or even timing belt issue? Daddy taught me the basics but not familiar w/all the computers & sensors in these new cars
  • Chrysler Master
  • 3,961 Answers
The knocking on acceleration, and the oil consumption indicate you probably have a failed big-end or conrod bearing in the engine. The classic test is to run the engine at a moderate idle and pull the plug leads off then replace them, in turn. If one shows a marked decrease in the knocking noise, that cylinder likely has a failed conrod bearing.
Positive diagnosis can be made by placing the car on a hoist and removing the sump. The suspect bearing cap is then removed. If the crankshaft bearing surface is not damaged, repair is easier, but mostly it will be scored, and then the engine has to come out.
I hope it is not this, but if so, it may be cheaper to just fit a reconditioned "short" motor.
Posted on Jan 03, 2014
2007 Kawasaki Vulcan 1500 loud knocking sound
Hi, Jeff I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fronk Forks---Plunk
9. Gears---WHINE
10. Head Gasket---HISS
11. Hydraulic Lifters---TAP
12. Pistons---SLAP
13. Rear Shocks---SQUEAK
14. Shifting Trans---CLUNK
15. Solid Lifters---TICK
16. Starters---CLICK
17. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Knocking Vulcan Noise Could be caused by damaged balancer dampers
Engine knock Vulcan Bagger Forums
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
Download Manual 2007 Kawasaki Vulcan 1500 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 21, 2017 | 2007 kawasaki Vulcan 1500 Classic
What can cause knock sensor to get bad on 2007 ford edge
Well the knock sensor does not make any noise. It senses the vibration in the engine if there is a spark knock to let the computer know to slow down the spark timing.
You probably have a weak piston or lifter or rod bearing making the noise.
Jun 16, 2015 | 2007 Ford Edge SEL
2003 chrysler concord nocks pings left side
Knocking and pinging are two separate things. "Knocking" usually refers to the sound an engine makes when internal mechanical parts, such as piston rod bearings or connecting rod bearings, begin to wear and cause a deep "knock, knock, knock" sound during engine rotation. "Pinging" refers to the tapping sound you get upon acceleration, either when using fuel that is to loo octane for the vehicle, or when static timing is set too far advanced, or when the cylinder heads are overheating due to clogged water channels or thin oil.
If you are hearing KNOCKING on the left side, it is likely time for an engine rebuild. If you are hearing PINGING, you may need a better grade of fuel, or you are way overdue for either an oil change or a major tune-up.
May 10, 2015 | 2003 Chrysler Concorde
Replace knock sensor in 1997 Toyota Tacoma 3.4l
is this a question formed as a statement?
i want to, ?
how to?
where is it.
why do you want to?
did the scan tool tell you its bad.
is the engine knocking or detonation or pinging?
is engine running lean (i sure can ping,but the knock sensor rolls back(via pcm) all spark timing, so that ping ends.
why not post symptoms first with a question,
someone broke mine
it unscrews.
so?
Jan 24, 2015 | 1997 Toyota Tacoma
What could possible make my 2.0 motor in my Chrysler Sebring knock?
That could be a number of things. So, I would start with the easiest first. You will want to isolate the sound/knock, it may be an exhaust issue/leak/broken manifold bolt, at the exhaust manifold(s) If you check engine light is on, you will want to have a diagnostic ran, which you can perform at just about any auto parts store for free. If the light is on, you may be looking at a faulty knock sensor, and that would be the easiest to fix. If the knock sensor is not the issue, then you may be looking at something a lot more serious, like a weak oil pump, worn out camshaft, bad lifter, or even bad valves.
I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya! Good luck!
Jul 11, 2013 | Cell Phones
Have a 96 geo prizm that won't accelerate very well and is making a knocking sound any ideas?
knocking is a big thing, its a cry for help.
can be minor to horrific
knocking parked? or only driving.
in neutal or park?
knocking hot block, or cold block or both? at what RPM>/
only real oil pressure gauge works, not the idiot lamp
when the lamp comes on at 3-5psi, the war was lost.
my 96 makes 55psi cold just cranking, want a video of that?
find the knocking first.
if can ,be knocked , parked.?
id check oil pressure. real.
use a $5 stethoscope. find it.
drop all belts. to see if an accessory device knocks. (5min test max cold to start, yes, water pump dead)
PS/AC/ALT dead too.
still knock>
listen at valve cover. coming from there.
is the timing belt is old over 60k thy all shard and some knock load hitting that cover, it a for sure thing, skipping the 60k mile service point,
exhast header collerctor fange gasket , bad, allowing bang band bang as the 2 flanges pound themselves to death.
the top of the engine, see induction pips. (AIR) those mounts for sure can bang away, bolts missing.
knocking:
1 overheated the engine so bad its pinging? knocks up hills?
2: say exaclty when and not you get the knocks.
Dec 03, 2012 | 1996 Geo Prizm
My 2007 chrysler Sebring has a whinning noise when starts. After it starts, it sounds like knocking on the left side which is the passenger side under the hood.
I have the same problem with mine. We just took it to the dealership this morning and they said it was the alternator. Said they have been seeing alot of these. My dealership wanted to charge $800 to fix it, so now my husband is trying to replace it himself.
Oct 20, 2011 | 2007 Chrysler Sebring Sedan
Where is the knock sensor located and what does it look like?
Your vehicle is equipped with 2 knock sensors. They are located on the cylinder heads under the intake manifold. They look like the picture below.
NOTE: Most knock sensor codes are caused by mechanical problems with the engine like pullies that are "rattleing" or lifters that are "tapping" etc. The knock sensor does not know the difference between "ignition ping" and mechanical problems like those mentioned. Knock sensor codes set when the engine computer has retarded the ignition timing as far as it can in an effort to stop ignition ping and the knock is still present. This is usually because the problem is not caused by ignition ping.
Feb 22, 2011 | 1994 Lexus Es 300
Knocking when i stepped on the gas aqnd when i slow down, on my 2007 nissan sentra
if you are talking about a pinging upon acceleration then we are talking about a knock sensor and chances are you have a check engine light on. verify the code and replace the knock sensor.
Nov 02, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Knocking sound from motor
sorry no adjustment, try an oil change with mobile 1 5-30 you may just have a collapsed lifter from letting it sit -jeff please rate
Sep 01, 2008 | 2004 Chrysler Sebring
Chrysler 2007 Sebring Touring Logo
131 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
