Question about Mitsubishi XD490U Multimedia Projector
Mitsubishi xd490u projector wont turn on
I plug it in and it wont power on the power and status lights come on then go off and the power button blinks red and green, once in a while the status light will blink red twice, what does that mean/how do i fix it??
3 Suggested Answers
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
  • 30 Answers
SOURCE: i plugged in my xd490u
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Posted on Feb 28, 2011
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Mitsubishi projectors lamp turned off after 2 minutes
Possible that the cooling fan is not operating , the filter is clogged or there is fault on the power section/motherboard and so it trips off.
Need to probe within to confirm if you can check on the filters, the lamp door switch and the lamp seating.
Nov 11, 2011 | Mitsubishi XD490U Multimedia Projector
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
Mitsubishi projector xd490u turns off and on in seconds
This is likely to be a heat issue of some sort. Please make sure that all of the airways to the back of the set are clean.
Feb 26, 2009 | Philips 60PP9202 60" Rear Projection...
To jmatthews
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
Mitsubishi XD490U Multimedia Projector Logo
54 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Martin Murray
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
