No signal on Benq T902HDA MONITOR - Computers & Internet
Benq t902hda
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Mar 11, 2014 | Computers & Internet
Benq t903
Hello
Possible bad Monitor video cable.Or video device is bad.
Try unpluging the pc completly from the wall for 5 min then plug back in and restart.
Also check that connections are solid and tight on monitor video cable.
Apr 29, 2010 | BenQ T903 19" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
I bought a Lenovo S10e last week, for my mum, the monitor was to small for her, so today I bought a Benq g2220hd monitor, problem is that I dont get a signal on the Benq monitor, I did get the windows logo...
first i would check the compatibility of the monitor to the laptop and see what they say, and if it should work odds are the monitor will have to be set manually through the laptop itself or on the menu of the monitor itself, may take a while playing cat and mouse but im sure you will get it, more then likley from what im understanding its a resolution issue between the monitor and the laptop, especially if you got the windows logo on the boot
enjoy
Jul 06, 2009 | BenQ Computers & Internet
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Jan 15, 2008 | BenQ FP731 17" LCD Monitor
What is the triggering signal to power on the monitor?
Most modern monitors use the Horizontal sync line to determine when to go to standby.
Aug 18, 2006 | BenQ V773 17" CRT Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
