Question about Harman Kardon HS 200 Theater System
Factory reset when you turn it on ,de volume button is bleu en in the display coms POWER ON . nothing more . gr dennis
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
How to hard reset?
      To do a factory data reset, follow these steps: If your phone is on, turn it off. Press and hold the Volume up button and the Power button at the same time until the device turns on. Press the Volume down button to select "Recovery mode."
      Reset your Android One to factory settings - Android One Help
      https://support.google.com/android-one/answer/6088915?hl=en Google
    Feedback
    How to Hard Reset an Android Phone ' Smart Mobile Phone ...
Jan 16, 2016 | Cell Phones
How to reset lg g2 phone
It will erase everything Hardware factory reset Take your phone and turn it off just press power button and select power off.Wait while your device is shutting down.Then, press volume down button and power button together until the LG logo appears on the screen.When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.Once you do that, on your LG G2 the factory reset menu will be displayed.Press power button in order to agree and wait while the hard reset is being completed.
Aug 15, 2014 | LG Cell Phones
Samsung galaxy S2 mini keep restarting itself...i can t get to the menu to write codes or restore factory settings...it just resstart over and over again.....the button is not blocked and i tryed some...
Press volume up & down & power - when the phone vibrates IMMEDIATELY press the home button and after 2-3 seconds release the power button... What you're going for is that the phone tries to restart with volume up & down & home button pressed...
Press and hold both Volume UP and DOWN + POWER ON / -->( HOME ).
Select Factory reset with Volume Down button and press Power to reset. All data will be lost!
or
Turn off S6500. Press and hold POWER + ENTER button for reset menu.
Mar 07, 2014 | Samsung Galaxy Cell Phones
I have locked myself out of my tablet
You will need to do a factory reset:
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Reset samsung p1000
Tous les codes hard reset de Samsung
Oct 25, 2013 | Tablets & eReaders
Nexus 7 wont turn on
You can try to do a hard reset by holding down the power button and the volume down button for 20-30 seconds. IF the device still will not turn on make sure it has enough battery or is plugged in.
If you still have problems you can try the following to do a factory reset:
  1. If your tablet is on, power it off.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
  5. While holding down Power, press Volume Up.
  6. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
Source: https://support.google.com/nexus/answer/2668187?hl=en
Hope that helps!
Sep 02, 2013 | Google Nexus 7
How do i do a master reset?
Performing a factory reset via settings The most convenient way to do a factory reset is via the phone settings.
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Ref: http://www.htc.com/www/howto.aspx?p_id=297&id=182
May 03, 2011 | HTC HD2 Smartphone
Harman Kardon HS 200 Theater System Logo
43 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
