Fisher paykel how to
Font panel buttons
  • 106 Answers
SOURCE: cannot access pump in fisher & paykel washing machine
There has to be some access somewhere, behind?. Find it out, the problem is with your pump, unplug washer from the electric mains. Drain out your water by lowering the exit hose into bucket or ground drain, dismantle your pump to see what is clogging it. Before that see that the connections to the pump are tight; pull out and refit, it might sort out the problem. Or you have to change the pump. You can do all these yourself. Only note careful as to what came out how & how to refit.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Posted on Mar 15, 2009
MNfisherman
  • 11896 Answers
SOURCE: fisher paykel GW 11, no power to panel.
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
Posted on Jul 07, 2009
  • 34 Answers
SOURCE: service fault 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Posted on Aug 03, 2009
  • 159 Answers
SOURCE: my fisher paykel washer stopped in the middle of a...
Either the computer board is dead OR the pump was on it's way out & took the board with it.If your lucky the pump is just dead & therefore not providing power up to the board,thats the cheaper way to go first.Or you may be up for both.It was probably pumping out at the time when it stopped.
Posted on May 29, 2010
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: customer.care@fp.co.nz
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Email: customer.care@fp.com.au
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Email: customer.care@fisherpaykel.co.uk
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Aug 21, 2017 | Fisher Refrigerators
Fisher paykel dishwasher
If the panel display on the lower drawer is lit and you can select the program then most likely the water inlet valve is fault and needs replacement. But if the panel is dark and none of the buttons operate then the power to the drawer is cut off. This can be due to a number of reasons including the power board at the base loosing one power circuit or the thermal fuse in the drawer is blown. Please provide model number of dishdrawer unit and also please describe what is actually happening.
Jul 30, 2014 | Fisher and Paykel Dishwashers
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
FISHER PAYKEL DRYER
there is a reset button located inside the front panel on the dryer. Try pushing it.
Jul 14, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel dryer
buzzing sound generally come from the motor assy, not necessarily a bad motor however. try opening the front door and along the inside of the top of opening is 2 phillips screws the top will tip back and then removing 2 5/16 screws from inside the font panel will remove giving you access to the motor blower assy.. it is possible that something( baby sock, small undergarment) has fallen inti the blower preventing free spin also resulting in a buzzing noise, if so simply remove debris and reassemble.
May 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
