Question about Canon PIXMA MX320 Color USB InkJet Printer
HOW DO I USE ONLY ONE INK CARTRIDGE FOR BLACK INK ONLY
  • 27 Answers
Go the printer preferences, click on tools - click on ink, the choose black only. if you select black only, it will just print black, even with color pic
Posted on Mar 11, 2014
Canon mx479 printer printing with white line through text on every other line
does this Canon mx479 printer have a self clean
or maintenance menu
user manual link
https://www.manualowl.com/p/Canon/PIXMA-MX479/Manual/218086
something wrong with the black printer cartridge
PG-240XXL XXL Black Ink Cartridge
PG-240XL XL Black Ink Cartridge
PG-240 Black Ink Cartridge
CL-241XL XL Color Ink Cartridge
CL-241 Color Ink Cartridge
May 11, 2016 | Canon Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
Lexmark x3430 need ink cartriage
This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
Lexmark - 24 Ink Cartridge - Color
Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
Lexmark - 23 Ink Cartridge - Black
Compatible with Z1400 series, X3500 series and X4500 series printers;
Sep 15, 2008 | Computers & Internet
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
Canon PIXMA MX320 Color USB InkJet Printer Logo
80 people viewed this question
old marine
old marine
