Question about ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard
Unknown cpu detected asus.Bios update is required to unleash its full power.
  • ASUS Master
  • 4,134 Answers
You will get this message when you install a CPU that is not supported by the mainboard BIOS. Many older mainboards have sockets that will support much more powerful CPUs than they were originally manufactured for. In some cases, the BIOS may be upgradeable to support the new CPU, in others, the CPU may draw too much power or the mainboard chipsets will not support the CPU capabilities. If your CPU is on the list of compatible CPUs...you may need to upgrade the BIOS to support it. You will need to install a CPU that the mainboard will run with to do the BIOS upgrade prior to installing the new CPU, however.
Posted on Jan 04, 2014
3 Suggested Answers
  • 73 Answers
SOURCE: ''unknown cpu detected,bios update is required to unleash its pow
Ensure that you download the BIOS update from the ASUS Website - nowhere else - and that it is for your exact motherboard model.
Instructions are here:
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
I am a bit surprised that they still require you to copy the files to a floppy/USB and boot into DOS. Last time I updated my Phoenix BIOS the utility ran from Windows. But anyway, that seems to still be the procedure for ASUS boards.
Posted on Sep 24, 2009
SOURCE: Unknown CPU detected, BIOS update required to
hi
yes u can run Intel Core 2 Duo e7500 on Asus p5vd2-vm socket LGA775 .
spec link's
http://www.asus.com/product.aspx?P_ID=2sYAtam7ng8vCngf
http://ark.intel.com/Product.aspx?id=36503
Posted on Mar 22, 2011
ASUS K8V-MX motherboard "UNKNOWN PROCESSOR"
There is a processor installed that the BIOS cannot recognize. Update the BIOS in the motherboard.
http://www.asus.com/Motherboards/AMD_Socket_754/K8VMX/#download
Also make sure the CPU is in the CPU support list, on the same page. If it is not a supprted CPU, you will get that error.
Apr 21, 2011 | ASUS K8V-MX Motherboard
Unknown CPU detected, BIOS update required to unleash its full power after update ... hello, can i run an Intel Core 2 Duo e7500 on an Asus p5vd2-vm se i need help plz
hi
spec link's
Mar 22, 2011 | ASUS Computers & Internet
Asus p5vd2-vm se Unknown CPU detected, BIOS update required to unleash its full power after update the bios
http://download.cnet.com/biosagentplus/3000-2098_4-10175528.html
This is an efficient, easy-to-use tool to help you figure out the details that make your computer tick. BIOS Agent is a lightweight freeware application with a clean and well-designed interface that lets you get the information you need with only a few button clicks. The program can retrieve information on the type of BIOS your computer runs and chipset type, as well as information on CPU, ROM, and RAM. Once you've gathered the details you need, you can save the report in TXT format or print it. There's no installation required for BIOS Agent. This program will be useful for administrators or power users looking to keep their systems up to date. hope this helps
Mar 22, 2011 | Computers & Internet
After assembling my new asus P5KPL-CM MotherBoard with Core2Duo 2.8 GHz Processor, I get a msg on post; 'unknown cpu detected,bios update is required to unleash its full power' apart from now having to hit...
http://www.asus.com/product.aspx?P_ID=6nnVb6RBxd7PhGmt#
If the link does not work use the search feature for the P5KPL-CM the go to downloads.. it is rather easy to do and can be done on the boot up through easy flash utilities from a USB Jumpdrive
Select the Operating system you are using and Download the newest bios. i had a similar problem with my CPU untill I upgraded the BIOS now it is running like a champ.
Sep 03, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
you have reset your bios setup
if pbm continues
u have replace the enter bios chip
Nov 25, 2009 | ASUS Motherboard P5n-mx
Sep 24, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Same problem
You need to flash the bios to a newer version for this cpu to be supported by your motherboard. Your descriprtion says asus so go to www.asus.com; click on the support link; lookup your specific board model #; select the operating system you are running. Download the latest bios file and follow the directions on the download site for proper flashing. Once you have flashed the bios everything should identify properly and allow you to continue setup. Hope this helps.
Jul 19, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ASUS P5KPL-CM Bios Problem with Core2Duo 2.8 Ghz Processor.
I recommend going to this site and getting the latest Bios for the board.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I don't know your expertise with computers but it will require you downloading their Bios boot disk utility and creating a boot disk. then copy the Bios file to the same disk. When you boot it up it will guide you through the Bios flash process.
Be aware that you can completely kill the Bios if it has a problem during the flashing so only do it if you are positive you can get through it.
Alternately if you can push the F1 and get into the OS the Motherboard utility disk should have an updater you can use from inside windows.
May 04, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
