Question about Emporio Armani Watches
How do I wind up an Armani AR2053 watch
Have a new watch for Christmas but I can't get it started? I have wound it clockwise and there isn't any resistance. I have also tried wearing it and gently rocking it but nothing is working!
  • Emporio Armani Master
  • 18,424 Answers
This watch is battery operated QUARTZ make sure you av pushed the crown fully in, if that doesn't work it needs a new battery.,,
Posted on Jan 03, 2014
  • 10 Answers
SOURCE: I have S.U.G WATCH(AUTOMATIC)I WEAR IT ALL DAY BUT WHEN I TAKE
hi...either the generator is shot or the rechargeable battery...yes, it should run overnight....my guess is that it should run a couple of months without wearing/charging it...I suggest you mail it back to the manufacturer.....d.
Posted on Nov 12, 2008
  • 4 Answers
SOURCE: problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: WIND UP MY ARMANI AR0203
Try puting it off and wind it then.
Posted on Dec 31, 2009
disap1
  • 98 Answers
SOURCE: New Tag Aquareacer Automatic wont manualy wind
If thats a new watch then there could be an issue in the movement and its possible it could be covered under warranty. Take it back to the store asap!
Posted on Jan 16, 2010
  • 8 Answers
SOURCE: Watch will not wind. Wound
The best solution is to lightly tap on the watch, this will keep it running until the spring is unwound enough to run on it's own.
Posted on Jan 08, 2011
It stops working it will not stay on the correct time
This watch is a self winder and thrives on being used. When fully wound, they should run for 2-3 days and if they run right down then they need to be wound up and used to maintain operation.
I am not sure if this watch can be manually wound but try turning the crown in a clockwise direction. If this is not possible, to wind it up, wave it from side to side for a few minutes (200-300 times) and his should wind it sufficiently to run for a day or so.
Wearing the watch daily is sufficient to keep it going.
Feb 18, 2011 | Rolex Daytona 116520 Wrist Watch
My Cartier Roadster does not keep time in my watch winder, all other brands work except this one. Any idea why, should the winder be set at clockwise, counter-clockwise, or bi-directional.
I believe the Roadster uses the 2892 movement and as such should wind in either direction. Find a competent watchmaker and ask him/her to check the automatic winding mechanism for proper rotation. I am assuming this is a real Cartier.
Jan 17, 2011 | Cartier Roadster W62019X6 Wrist Watch
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
Does anybody know which way i'm supposed to wind my cartier santos watch? Options: clock-wise, counter clock-wise, or multidirectional?? thanks
mcdevito75 here, Generally your Cartier watch is wound in a clockwise direction simply, due to how it:s made, in this direction the mainspring is tightened or wound and turning the crown in a counter-clockwise position only free wheels the winding mechanism. I would advise you wind your watch in a multi direction, however not to the very, very end of It"s winding capacity, once you feel the crown getting tension only 4--5 more multi-direction turns should be enough to maintain a good wind to your Cartier watch.
Aug 15, 2010 | Cartier Santos W20011C4 Wrist Watch
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
Jul 10, 2010 | Giorgio Armani Emporio Armani watches...
Armani watch AR0402 has stopped working I have tried to wind up with little avail what can be the problem
Your watch is battery driven. Visit your nearest watch repair shop and ask for new battery.
Feb 01, 2010 | Giorgio Armani Armani Leather Collection...
Dec 31, 2009 | Giorgio Armani Emporio Armani AR0203...
Watches Logo
418 people viewed this question
Top Emporio Armani Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Emporio Armani Watch Expert? Answer questions, earn points and help others
