Question about Tview D65TSG 6.2" In-Dash Navigation
Wont keep time
Loses time every time the car is turned off
    New Friend:
  • 17 Answers
When you wired your radio you didn't connect the 12volt constant wire correctly so identify that and connect it where the red wire is
Posted on Feb 14, 2014
1997 grand cherokee keeps acting like losing power, backfires and randomly shuts off and now it wont start again...any suggestions??
timing belt may have slipped. usually if the engine starts to back fire and then lose power the timing belt is loose. would check this and replace if it looks suspect. also timing belts should be changed at a certain time or miles witch ever is the grater. average is 4-6 years on a engine that don't do meany miles 2-4 years on a heavy run engine.
Oct 15, 2013 | 1996 Jeep Grand Cherokee
Land cruiser 2010 timing belt warning light ON, how can reset?
not sure if thes will work for you but try it you wont lose any thing :
turn the key on hold the odometer button in and turn the key but don't start the engine and keep holding the button for 10 ten seconds then lift your finger off the button and the number 1 should come up now this number represents 10,000 K's so what you do is keep pushing the button until you reach the desired K's you want you can go up to 20 = 200,000 K's and then you hold the button in for another 10 seconds then let go and turn the key off and turn it back on and it should be gone i know this works because I've just done it today
Mar 26, 2013 | 2010 Toyota Land Cruiser
Car wont start, been having battery issues usually jump start works not this time. makes a clicking and rattling noise but wont kick over. May be unrelated but it has been shaking when speed over 55 was...
BATTERY COULD BE WEAK.CHECK BATTERY VOLTAGE SHOULD BE 12.6 VOLTS. REPLACE BATTERY CABLES 14 YEARS OLD. IF BATTERY CABLES OKAY.REMOVE STARTER HAVE STARTER AND SOLENOID TESTED AT ANY AUTO PARTS STORE FREE.BE SURE TO TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE.DOING THIS KEEP YOU FROM LOSING RADIO CODE.
Sep 04, 2011 | 1997 Ford Escort
My Pentax wont keep its date or time. I set it, turn it off and on again and it has reset to default date
http://www.pentaximaging.com/files/manual/istD_IB.pdf
Most likely the batteries need to be replaced, or they are being jostled and losing connection with the resistors in the battery bay.
May 21, 2011 | Pentax *ist D Digital Camera
2003 chevy suburban wont start in the morning after sitting over night, if it has less than half a tank of gas?
it sounds like you have a fuel line problem inside the tank,maybe a pinhole, once fuel level gets below pinhole the line loses pressure. once it loses pressure you have to keep turning switch on & off too get pressure built back up.
Jan 12, 2010 | 2003 Chevrolet Suburban 1500
Wont start
losing water for months, but no eveidnese under car. Either being blown out exhaust or it's in the oil. Pull out oil dipstick and check if oil if foamy or too thin. That would mean the presents of coolant in the oil. And that happens from bad headgasket.
This could keep from starting depending on how freezing.
Dec 22, 2009 | 2001 Daewoo Lanos
Car wont start possible jump timing
car wont start could be many things.your timing belt change is due at 60000 miles.if you at a 100000 miles and not change it.you timing belt have a tensioner that keep it tight. .when it wears it loses tension and cause timing belt to slip time.i would check fuel system and ignition system for spark first before having.timing belt change. its going to cost you.
Jul 15, 2009 | 2001 Hyundai XG300
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
Power shuts off randomly
Sounds like you have a bad connection somewhere. pull the radio out and check your power and ground connections to ensure that they are tight.
Nov 17, 2008 | Alpine CDA-9857 CD Player
Keeps losing the time ?
if you turn the ipod off all the way the unit turns down completly and is all use up a lot of battery power its somthing apple is still looking into so you sould leave it on standby and you will keep the same time and actully save battery life.
Nov 16, 2008 | Apple iPod touch
Tview D65TSG 6.2" In-Dash Navigation Logo
56 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
