Question about Asko W6021 Front Load Washer
Cost of motor replacement for asko w6551
What would be the cost of replacing wash motor?
2 Suggested Answers
  • 351 Answers
SOURCE: replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Posted on Jun 16, 2010
I activated the child lock system when the kids were young, now I need to deactivate it. How do I do this?
It varies from make and model. the instructions will be in the user manual.
May 24, 2016 | Washing Machines
Asko 20004 washes but won't spin
This is a motor fault issue. As I don't know your ability in repairing or what tools you possess. Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes. There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting. This is not complex just dirty I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
Nov 18, 2013 | Asko Washing Machines
Where are the brushes located on an asko washing machine ??? I'm fairly handy, can I replace myself ???
hi, I used to fix asko's when I was as work and found the motor brushes really easy to fix on the older machines. I found it best to drop the motor down and change the brushes at the back of the motor on the bench. hope this helps. remember to change both brushes though.
Mar 25, 2013 | Asko Washing Machines
Had a "wash motor fault" in July 2007, had a
Welcome to FixYa.
This can be associated with worn brushes in the motor or a sign of a damaged spot on the motor armature, hence when you spun the drum off of the dead/damamged part the unit began to operate.
If capable one can remove the rear panel, and with the aid of a flashlight inspect the brushes and armature.
I'm surprised how often I hear of these motors being replaced when in most cases a new set of brushes will remedy the problem...alas I guess there is more profit for technicians for relatively the same amount of work in replacing a motor.
Let me know if the problem re-occurs or if you'd like a service guide into inspecting the components I alluded to.
Thank you.
Regards,
Macmarkus :)
Jan 13, 2011 | Asko W640
Where can i buy a motor for the Asko w600 in Ballarat
Hi just read your posting.Now the place to buy all spare parts for ASKO washing machines is in MELBOURNE. Asko has their factory in Moorabbin.If you ring up directory assistance and ask for Asko"s phone number they will provide it.Then you can buy the motor over the phone and it will take a couple of days for delivery.Unfortunately I do not have the phone number off hand.By the way why are you replacing the motor,maybe I could help with the problem.Please reply to let me know how you got on.Looking forward to your reply.
Aug 28, 2010 | Asko W600
Replace drum bearing ... in a ASKO W6551 step by step
Jun 05, 2010 | Asko WL6511W Front Load Washer
When I start my dishwasher it will initally drain any residual water and then add clean water but will not wash the dishes.
I had the same problem and replaced the control board - problem solved. The good news is it's easy to replace; the bad news is a replacement board costs almost $300.
Jan 19, 2010 | Asko 24 in. D3120 Dishwasher
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Asko W6021 Front Load Washer Logo
37 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
