No cold air coming from the registers.
It is a central air unit. The fan blows on the outside unit. Air is coming from the registers, but it is not cold air, and the house remains the same temperature regardless of the thermostat setting.
  • Skinnerd1
    Skinnerd1 May 11, 2010
    Can you tell if the compressor is running in the outside unit?
    Is there ice on the larger copper line?
  • Dennis Boxerman May 11, 2010
    How about a model and serial number of the outside unit?
    Problem Solver:
  • 13 Answers
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
Posted on May 22, 2009
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Jul 22, 2009 | Heating & Cooling
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
