Question about Ricoh Office Equipment & Supplies
How to fix error code SC 620-01 for ricoh MPC2500
ERROR CODE SC 620-01 APPEARS ON AFICIO MPC2500 EVEN IF I RESTART THE PRINTER THE CODE STILL APPEARS HOW DO I CLEAR THE CODE
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
M2Tech1
  • 313 Answers
SOURCE: Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Posted on Aug 05, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Mpc2500 sc 620-01
That is a Controller error. Unplug hard drive and reboot. If it goes away it is a bad hard drive. If it does not, then the controller board is bad.
Jul 28, 2014 | Ricoh Aficio Mp C2500 Copier
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Hello, ricoh aficio 1018d error code display sc 925 what can i do for it.
IMB non-connected error
Symptom:
IMB is not connected. This SC only
appears with B040 and B043 version
machines.
Possible Cause:
• IMB is not connected
• Poor connection between BiCU and
IMB
• IMB defective
• BiCU defective
Sep 27, 2010 | Ricoh Aficio 1018D Copier
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Error SC 411 appears
SC411: Separation bias error
-Definition- [B] A separation bias leak signal is detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Discharge brush defective You need the service manual or have a technician fix it. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 15, 2009 | Ricoh (R) Aficio CL3000 Color Laser...
1,456 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
