Question about Saws
AEG Circular Saw CS 650
Can not remove saw blade
karmacanic
  • 16 Answers
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
  • 15 Answers
SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
Posted on Nov 18, 2008
muttandjeff
  • 359 Answers
SOURCE: how do i change the blade on craftsman circular saw?
some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Posted on Jan 02, 2009
efs_perpends
  • 1996 Answers
SOURCE: where is the lock button for the skill saw
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do i change the circular saw blade on my saw?
After removing the blade bolt and the outer flange you will need to fully retract the lower guard (remove battery) and sometimes wiggle the blade but it will come out.
Posted on Aug 29, 2009
Where can we buy replacement blades?
Circular Saw Blades from Freud Sold Online - Tools Plus
www.tools-plus.com/freud-circular-saw-blades.html
Saw Blades for Less at Tools-Plus.com. Free Shipping on 1000's of Products.
Circular Saw Blades, ALL Sizes, ALL Brands Sold Online ...
www.tools-plus.com/supplies-power-tool-blades-circular-saw.html
Circular Saw Blades for Less at Tools-Plus.com. ... Shop with confidence knowing that Tools-Plus.com is an Authorized Internet Retailer. 3-3/8" Circular Saw Blades .... Saws and Replacement Blades ยท Automotive Hand Tools and Equipment ...
Nov 02, 2015 | Saws
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
Saw blade not spinning with the motor, on my Black & Decker CS 716 circular saw. Is there a reset? cheers md
This model has the blade linked to the motor via a pinion on the motor shaft and a gear wheel bolted to the blade. Normally there is no way that the motor can rotate but not the blade. However, the pinion can fracture leaving the motor to run free. Repairing this involves replacing the entire armature unit, which will cost more than the saw is worth.
Jul 20, 2011 | Garden
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
How to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Oct 09, 2010 | Skil 538501 120Volt 714Inch Circular Saw
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Oct 02, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
The spindle locking pin has sheared off internally and i cant remove the saw blade how can i do this.the circular saw is the draper 1300w
One way is to lock your saw blade into a vise and remove the blade retainer. I am not sure if you have a bolt or some other type of retainer. Whichever it is you always turn in the direction of the blade turn to remove. Any question please post back.
Nov 01, 2009 | Saws
How do i change the circular saw blade on my saw? because i cant get the blade out to swap it as its blunt and the blade is now blunt
Aug 29, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
How to lock blade on older circular saw
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Nov 23, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
