Question about Logitech Inc Arena 685 5.1 Multimedia Spkr Computer Speakers
Wire diagram for labtec arena 685 - Logitech Inc Arena 685 5.1 Multimedia Spkr Computer Speakers
Loud buzzing from all speakers
Try make sure all cables are fully PLUGGED in... inserted all the way
Jun 04, 2012 | Labtec Arena 675 Computer Speakers
I Need a Complete Diagram to Install Mitsuba Arena Horn
Were you able to get the disgram of mitsuba arena installation manual?
Jan 17, 2011 | GPS
I have relocated my PC (HP Pavilion a1604n) which necessitated disconnecting everything. Now I'm trying to connect speakers etc. but cannote locate manual. Where do all these plugs go?...
On the Back of the Case there are connections for the Mic and the sound look for the In or Out Connections You may have plugged the speakers into the wrong plug go to this page FOR A MORE DETAILED test
http://www.5starsupport.com/faq/sound.htm#1-6
Jun 02, 2010 | Labtec Arena 530 Computer Speakers
Dra-685 the protection came on ,i found 2 speaker wires together,fixed that,but still stays on,thanks
You may have a speaker that is damaged and causing the protection to operate. Try unhooking all the speaker wiring from the receiver, turn the volume to minimum, and see if the protection still comes on. If the receiver is okay, you can start checking the speakers and wires to determine which one(s) may be responsible.
If the unit continues to go into protection even with no speakers connected, the trouble is inside the receiver. No protection circuit is absolutely perfect, so it's possible something failed before the circuit kicked in. Without the proper test equipment and service information, you won't be able to try fixing this yourself. Take the unit to a shop for an estimate.
Thanks for using Fixya! Hope your receiver's back in service soon.
Feb 02, 2010 | Denon DRA-685 Receiver
I broke my transmitter. What can I do?
Hello
it is not worth the effort, go a buy a mouse, its going to cost you around 10 for a basic wire mouse. the time and effort to make your old one wired, its not worth it.
Jan 08, 2010 | Logitech Labtec Wireless Laser Mouse
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
Labtec LCS 1024
I don't have a wiring diagram for you but can tell you this as standards apply.
Red is always the positive (+) terminal and black the negative, ground, (-) terminal. FYI-though people use the term ground it is not correct.
Another thing you should know is red and black are relative. Inother words, when red to red and black to black it will cause an outward motion of the speaker. If you happen to reverse them, red to black, it just causes an inward motion of the speaker. Sometimes this is refered to as the "phasing" of the speaker.
Speakers are usually marked at their connection points with a red dot or a (+) for the positve and a black dot or (-) for the "negative" side.
So there's nothing to worry about if this happens anyway except:
if you were to go red-black on one speaker, and red-red on the other. This will cause the speakers to be in series which normally wouldn't hurt things, but make sure it's not done just in case you amp section cannot tolerate this condition.
Hope this helps.
Jeff
Mar 19, 2008 | Labtec LCS 1024 Computer Speakers
Logitech Inc Arena 685 5.1 Multimedia Spkr Computer Speakers Logo
61 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
