Two outlets mistral mpac50 which one drains the water
4 Suggested Answers
  • 400 Answers
SOURCE: Hi have just purchased a
Yes, we could.
Posted on Mar 12, 2009
hvac1960
  • 2133 Answers
SOURCE: hi, my mistral (MPAC50 just
E5 Outdoor activation of compressor over heatprotection or motor lock
Compressor overheated due to condenser block or fan motor lock. Clean condenser/replace out door fan capacitor.
Posted on Dec 30, 2010
evehardes
  • 3 Answers
SOURCE: How to reduce temperature in mistral mpac50 sitcom
Have you tried changing the mode to the snow flake looking symbol?
Posted on Dec 01, 2012
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
Zanussi zwf1437w
Possibly blocked sump hose( bottom of drum) or pump not running,,,,drain water by putting outlet hose down too ground level, when water drained out put machine on spin. If machine spins ok, then you have a pump problem,,,,if water won't drain out when outlet hose at ground level then you have a blocked hose
May 25, 2013 | Washing Machines
Nov 30, 2012 | Heating & Cooling
Water in the drivers footwell on Mistral
look on hooded vent area( under windshield whippers) sometimes there is a drain line that gets plugged with leave and dirt use a air line blow through and clean out this should do it
Apr 30, 2012 | 2004 Nissan Nissan almera tino
Hi, my mistral (MPAC50 just started coming up with an error code E5. it wont go into airconditing mode and only uses the fan
Dec 30, 2010 | Heating & Cooling
Water tank still gets full when connected to floor drain
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Jun 07, 2008 | Danby DDR600R Silhouette Dehumidifier
MISTRAL MTLW7..2 too many probs!
e4 error on my mistral MTLW7 washing machine want spin
Mar 27, 2008 | Washing Machines
I have a mistral MTLW7 washer and it is having trouble with the spin cycle, it comes up with an error code on the display screen, and will not spin again, as all of the clothes are over one side. The...
Im no expert but i have found the hight of the water outlet is kinda critical to correct function on mine.
The manual states outlet to be no less than 700mm and no more than 1200mm and i have mine now at 900 mm and its all working fine.
Originanly was hooked in under sink and exerienced similar problems
Hope this helps ya out
Dingo~
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
