Question about Bosch Washing Machines
Wfd 1661 by - Bosch Washing Machines
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
I forget my security code on my nokia 1661-2, how can i reset it to default without using it? Nokia 1661-2 IMEI # 354198038352831 RH-122
Hello Irfan,
Switch off the Nokia 1661-2 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 1661-2 Cell Phone. Enter the default code 12345 or 00000.Your Nokia 1661-2 Cell Phone will be unlocked.
Oct 22, 2011 | Nokia 1661 Cell Phone
NEED TO UNLOCK
You can get the unlock code for your nokia 1661 at here by use this http://www.theunlockspot.com/nokia-1661/rs10wp9/ link and also following instructions willmade you at more easier way to unlock your mobile..
Warning : Do not enter any wrong unlock codes on your Nokia 1661 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1661 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1661 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1661.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1661 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1661 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1661
hope its helpful...
May 13, 2011 | Nokia 1661 Cell Phone
Unlock code nokia 1661
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
In order to get your free unlock code for your Nokia 1661, you will probably need your phone’s IMEI number. You can find your Nokia 1661′s IMEI number by simply typing *#06# and hitting enter. Your 15-digit IMEI number will then be displayed on the phone’s screen.
Anyway, now that you have your phone’s unlock code, you can start the unlock process. This is actually probably the easiest part of unlocking your phone. I took these steps from my original phone guide on How To Unlock A Nokia Phone.
OR:
As you seem to know unlocking a Nokia 1661 requires an unlock code. You can find both some methods on getting a free Nokia 1661 unlock code as well as some unlock instructions from this Nokia 1661 Unlock Guide.
1. You need to get the unlock code for your 1661 to be able to unlock it. This might help: http://unlockgenie.com/Unlock-Nokia-1661
2. Once you have the unlock code, follow these steps: http://unlockgenie.com/How-to-Unlock-Nokia-1661
OR:
You go to Link
http://www.google.com.pk/webhp?hl=en#q=unlock+code+nokia+1661&hl=en&prmd=v&source=univ&tbs=vid:1&tbo=u&ei=w4tmTIzFEY_auQOD6Yz-Aw&sa=X&oi=video_result_group&ct=title&resnum=4&ved=0CCgQqwQwAw&fp=632033e523beb4ee
Thanks
Aug 14, 2010 | Nokia 1661 Cell Phone
Nokia 1661-2 unlock security code nomber
I fprgot my phone code.I want to decode my Nokia 1661-2 RH-122, Please give me the solution.
Nov 14, 2009 | Nokia 1661 Cell Phone
Unlock nokia 1661
As you seem to know unlocking a Nokia 1661 requires an unlock code. You can find both some methods on getting a free Nokia 1661 unlock code as well as some unlock instructions from this Nokia 1661 Unlock Guide. Good luck!
Oct 02, 2009 | Nokia 1661 Cell Phone
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
20 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
