Question about Refrigerators
How to remove the blade kenwood cuisine mixer
Can't remove the blade which I think should come out so as to remove the bowl
SOURCE: Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Posted on Jan 29, 2007
mirran
  • 515 Answers
SOURCE: kenwood A901
Contact a locale store that selling kenwwod and ask for a splashguard, the spare part number is KW604349 it´s a 'D' shape
Posted on Jul 11, 2008
ukvacfan
  • 328 Answers
SOURCE: Need a replacement bowl for my Kenwood Chef
I have an Excel that has the D shaped bowl but the base of it is round. Since the Excel does have a round base you can fit any existing bowl onto the Kenwood including their newer stainless steel bowl.
Posted on Mar 13, 2009
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
supertech6
  • 513 Answers
SOURCE: I was making bred dough with the mixer and when
You have broken the intermediate gear in the head. This gear can be a bit of a problem to change. Here is the parts manual for the KSM150PS.
The part is probably #6, worm gear.
Check with Kitchenaid on where to buy parts.
Posted on Apr 21, 2010
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
How do you attach bowls to mixer
The bowl sits on a round plate. If the bowl cannot sit properly, moce the round base a notch on the right to give more bowl space.
Nov 27, 2013 | Kenwood Food Mixers
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kenwood Chef Bowl
Check out ebay , often you can find parts for Kenwood
Sep 18, 2009 | Kenwood KM300 Chef Stand Mixer
Does anyone know the model number of a stainless steel bowl to fit the Kenwood Chef KM300/
The model number doesn't really exist other than the fact that the stainless steel bowl is available for just about every Chef made. My own KM300 has a stainless steel bowl for example that came as standard - it however is the same bowl you can order from Kenwood or EBay under the A701/A901 model - all bowls from Kenwood can be fitted on the Chef model with the exception of the Major model which is a larger and taller machine.
May 06, 2009 | Kenwood KM300 Chef Stand Mixer
Mixer runs, but will not turn beater.
You are correct, in the mixer head above the attachment hub is a gearbox, and there is a fiber gear meant to do just that should something similar happen, it can be replaced, I don't know price, but if you are careful, and fair mechanically, it is a straight forward replacement.
Dec 30, 2008 | KitchenAid K45SS Classic Stand Mixer
Kenwood A901
Jul 11, 2008 | Kenwood KM305 Stand Mixer
Replacement stainless steel mixing bowl for kenwood chef A901D
I have the spare part number for the bowl.
KW638821 - bowl - polished - stainless steel
KW672487 - with handles bowl - mirror finish
try to find a store near you to get one.
Apr 15, 2008 | Kenwood KM300 Chef Stand Mixer
Jan 16, 2007 | Kenwood KM300 Chef Stand Mixer
Refrigerators Logo
14 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
