Question about Dishwashers
Lg ld1415 bottom arm not spinning - Dishwashers
4 Suggested Answers
  • 423 Answers
SOURCE: Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Posted on Apr 04, 2009
  • 464 Answers
SOURCE: Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Posted on Nov 08, 2009
heatman101
  • 43501 Answers
SOURCE: LG dishwasher bottom arm not spinning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syte
Posted on Sep 29, 2010
LDF7932ST LG dishwasher top and bottom arms not turning. Diagnostic test mode "power+spray+ rinse" does not work.
I put a new lower spray arm and very little water comes out of it. There is quite a bit of water that comes out of the middle and top. The top does not spin but has quite a bit of water and the middle spins really good.
Jun 25, 2011 | LG 24 in. LDF 7811 Stainless Steel...
The bottom spray arm on our LG dishwasher, Model LD-14AW3, will not spin. The diverter valve from top to bottom section does not operate, i cleaned it and the housing near the filter but still no go. any...
I have the same problem, well - similar. The diverter is moving for me, however it is moving to the wrong position. It seems to move between the upper arm and then blocking off, rather than upper arm and then lower arm.
Did you manage to find a solution?
Mar 25, 2011 | LG Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Nov 07, 2009 | LG Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Sep 04, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
Top arm doesn't spin
It is important to know that the upscale LG diswashers alternate between washing the top and bottom rack. So it is normal for some arm to not be turning at certain times.
Also, if this dishwasher is set to half load, bottom only, the top arm will never turn.
Oct 16, 2008 | LG LDF8812 Stainless Steel Built-in...
heatman101
syte
Aug 24, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
14 people viewed this question
Top Dishwashers Experts
Owen Barnes
