You might have pressed the 'Source selector' button; (AV) button. Just press that button again and again till the selected source appear as "TV'. Gopakumar Gopalan Google
My ILO TV has a source selection that can select where the signal input is coming from that I want to display. Do you have the sat hooked up to an HDMI input? If so try selecting that. If you do have the option of using HDMI - buy a cable and hook it up between the sat (assuming it does support hdmi) and the ILO (mine does, and it about 5 years old). This is the least problematic way to make it work. The Poodle Guy!
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
I own a 26inch, I may not see a Green and Red option but if you have the remote you can select TV MENU; from there you can use the down arrow to the bottom portion and you can also choose to do a factory reset if that helps. Otherwise at the top part theres a way to customize all; brightness, saturation, etc under picture choose Custom
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
