Question about Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
  • 51 Answers
If the faint noise is the motor running, the belt is broken.
Posted on Jan 06, 2014
4 Suggested Answers
SOURCE: Dryer won't start, Simpson Eziloader 4kg
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
Posted on Jan 25, 2008
dmftrucker
  • 1922 Answers
SOURCE: dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Posted on Jul 30, 2009
  • 93 Answers
SOURCE: how to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Posted on Aug 29, 2009
Hi, my 6 month old Simpson 5kg Eziloader dryer blew a fuse today. Have plugged it into a different power plug and now its not working and making a humming noise. Any suggestions?
have a service technician come and look the start/run capacitor for the motor
blowing a fuse then humming indicates a capacitator problem
Jul 07, 2015 | Dryers
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
My simpson 4kg dryer drum not turning,still heats,making a wuring sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2011 | Dryers
Dryer lost heat. simpson ezyload 4kg
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Whirlpool GEW9250 Electric Dryer
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
Broken main belt.
Aug 29, 2009 | Dryers
Dryer will not spin
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
315 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
