Question about Samsung RS2630SH Side by Side Refrigerator
Ice tray not filling
Ice maker not making ice. Ice tray not filling with water. Reset ice maker. Tray still does not fill with water.
  • 1462 Answers
SOURCE: rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Posted on Jun 13, 2007
22yooper
  • 828 Answers
SOURCE: Samsung Side by Side RS2544SL Freezer will not fill tray with water
Your problem may be in the water supply. Where the water connects to the back of the unit there is an electric valve, not a pump. The electric valve inlet orifice may be restricted, Shut off water supply and clean or replace the electric solenoid valve.
Posted on May 06, 2008
  • 5 Answers
SOURCE: Ice maker not working.........
Reset button on the bottem front right of ice maker
Posted on Jul 30, 2008
daddyo742001
  • 70 Answers
SOURCE: ice maker won't work
Temp needs to be down to 0 or below for ice maker to activate. once that happend arms that push ice out will go around and made switch in end of ice maker that turns on water selenoid valve that adds water. this could also be electronic switch. main thing is its cold enough to activate. If it don't work then Ice maker may be bad or no power getting to it. turn freezer as cold as you can may mean setting refrig side warmer. If it has coil under refrig clean it out. Air around frig should be 68 - 75 degrees if poss.
Posted on Jun 29, 2009
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
Ice maker stopped working in lg refrigerator lfx25976st/00
I just slide the ice tray to the left and down till it unhooks from the right hand side. Then unhook the wires from under the tray. To replace just repeat in reverse order. I have to take our ice tray out ever so often to clean it since we have well water.
There is a little square button up under the left hand side in the back. If you press that with a screwdriver or butter knife it will reset the ice tray and it return it to fill with water.
Sep 03, 2012 | LG Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Ice maker no making ice.water not filling tray
you have a bad water inlet valve located on the back bottom of frig behind the bottom panel-mike
Jan 26, 2010 | Kenmore Refrigerators
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
67 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
