Question about Palm Treo 700p Smartphone
Treo frozen with Treo logo on screen
The phone locked up and when I removed the battery and put it back in, the screen got stuck with the Treo logo and won't go any further. I also tried plugging it into the charger with and without the battery and it does the same thing.
  • Palm Master
  • 4,338 Answers
  1. Hard reset:
  2. Press and hold the Power (on/off) button on the front panel of your device.
  3. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  4. If you see a progress bar (see below), keep holding the Power button.
  5. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  6. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
HotSync note:Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 22, 2009
  • 24 Answers
It caused software problem you may get solved by above if works otherwise go for customercare to reinstal the software better ypu try above
i m giving again bellow
  1. Hard reset:
Thanks, Joe
Posted on Jul 04, 2009
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Phone frozen. Hard reset doesn't do anything
A hard reset will erase everything on the smart phone. If you still see your data, then you were not successful in performing the hard reset. In that case, what you have done is a soft reset.
Carefully try one of these two methods:
Main method:
1. Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
2. Push the up button on the five-way to start the reset process.
Alternate process:
1. Similar to the hard-reset of the Treo 650. Remove the battery cover.
2. Press and hold the Red radio button.
3. Use the stylus to depress the reset button next to the battery.
4. Push the up button on the five-way when you get a prompt to "Erase all data".
Aug 17, 2009 | Palm Treo 700w Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
It will not go away from the sync screen mode
Apr 07, 2009 | Palm Treo 755p Smartphone
Its locked up
Is your Palm Centro device locked up and frozen. You might want to try a hard reset. Here’s how.
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the second Palm logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Mar 31, 2009 | Palm Treo 500 Centro
Turns on then freezes
You may have to do a hard reset on your phone if you haven't already. This will erase everything that has been placed on your device since you have had it--contacts, pictures, videos, texts, emails, etc. It is important that all of your information is backed up to the computer by Hotsyncing your device. If you have not Hotsynced your device recently then you will lose all your information, but since it only goes to the Logo you may have already lost your information. I have a Treo and that happened to my device.
To do a hard reset:
  • Press and hold the on/off button while taking the battery out of the phone (DO NOT let go of the On/Off button while taking the battery out and do not release even after the battery is out).
  • Count to ten and then while still holding the on/off button put the battery back in (DO NOT let go of the On/Off button)
  • The phone should power up and show the Palm logo and at the bottom of the screen the black bar should keep getting longer until it reaches the other side of the screen. The screen should change and say "Access Powered" and then go back to the Palm Logo and that black bar at the bottom of the screen should get longer again.
  • If the phone doesnt show "Access Powered" and stays on the Palm Logo screen, then make sure that the black bar is as long as it can be and then release your finger from the on/off button.
  • There should be another screen that comes up and asks "Reset Phone?"
  • At that point you press the UP navigation key to say YES or the DOWN navigation key to say NO. Either one you press, will restart the phone and it should load fine thereafter.
Sometimes the on/off button gets stuck so you might have to play with it a little. If that the button still doesnt work, you need to take it in to a SprintNextel Service Center and speak with a technician who will open the device and test for any physical or liquid damage which could be causing the button to be inoperable.
Dec 18, 2008 | Palm Treo 500 Centro
Palm Centro locked
If you forget the password, the only way to get back in is to perform a "hard reset." Performing a hard reset causes you to loose all data on your phone unfortunately (numbers, texts, and all). Hopefully you've sync-ed up your data on your computer recently.
To perform a hard reset, do the following:
1 - Remove the battery cover.
2 - Take out the battery.
3 - Put the battery back in. An orange Palm logo will appear on your screen.
4 - While the logo is showing, press & hold the Power/End button until a black status bar appears on the screen, fills completely, and then goes away. Then you can stop pressing the button.
5 - Next on your screen will be a prompt to erase all data. Press up to say Yes.
6 - Next select your language and you have an empty phone to start a new. If you've previously sync-ed up your data, you can sync up now and add it all back.
Oct 23, 2008 | Palm Treo 500 Centro
Treo 700wx Problem
Take the battery out and leave it out for 4-5 minutes, then put battery in and reset while holding the red on button. It should work now.
Jun 24, 2008 | Palm Treo 700p Smartphone
Palm Treo 750v
Have you tried removing the battery then putting it back in?
May 25, 2008 | Palm Treo 750v Smartphone
Palm Treo 700p Smartphone Logo
454 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
