Question about Brother MFC 240C All-In-One InkJet Printer
Mfc-240c prints lines in black
My Mfc 240c printer has been leaving blank lines in my pages of printing it mostly happens on coupons printed from any site associated with coupons.com I have deleted and reinstalled the software for that website many times and it works for 1-2 prints but after the second page I'm back to spotty printing any help would be greatly appreciated
  • 27 Answers
It may be your printer head that needs to be flashed. if you have not use the printer in a wile, the ink drys out and clog up the nozels. Do printer head cleaning, if not work, use paper towel with a little warm water, press the printer head on it.
Posted on Jan 03, 2014
  • 46 Answers
SOURCE: Help with Brother MFC-8500 all in one printer
When you get the paper, can you smear the print with your fingers, or is printed on there properly.
if you can smear it, it would be your fuser not doing its job properly, if you cant, then its your replacement toner as it most likely incorporates the drum in it, which i think is your problem.
Posted on Jun 20, 2008
APremkumar
  • 564 Answers
SOURCE: Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Posted on Mar 02, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
SOURCE: Brother MFC 240C alignment problems
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
Posted on Jun 02, 2009
  • 1684 Answers
SOURCE: Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Posted on May 14, 2010
Testimonial: "I really appreciate the answer! I will go buy a new drum. Thanks again for your help! I appreciate it very much! "
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
My MFC 240 is printing blanks, with both black and colors. It is doing the printing motions but just coming out blanks.
Go into the printer properties and access print head clean. this should fix it assuming the ink tanks have ink in them!!
Apr 22, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Prints blue and black only
I have had this happen on mine as well. The nozzles are not clogged (which cleaning would fix) the lines going between them and the cartridges most likely has a clot in it. Call in Brother's tech support and have it replaced by warranty, I have so far replaced for the same problem twice.
Jul 28, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
