Question about Bernina Bernette 75
Bernina activa 125 foot control
How do you open the foot control
  • 1388 Answers
SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
Posted on Feb 10, 2008
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
  • 13 Answers
SOURCE: Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Posted on Jun 23, 2008
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this...
Posted on Apr 30, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: . The Bernina 135 has the needle stop up/down button. See . The manual for this model is .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
Can Bernina walking foot with soles and seam guided used on Activa 210 be used on 16 yr old Bernina Activa 230????
Please be advised that the newer machines (Classic models) such as the 130-180 and up, have a totally different geometry. This is to say that the older machines have a shorter distance from the center of the presser bar to the needle center. The newer machine design was increased to provide space for needle threaders etc. Older machines will use an older Walking foot model (still available).
Feb 27, 2014 | Bernina Activa 130
Free print manual
there are Bernina manuals as pdf's on their website,, then go to Support, choose your manual in the drop down box and download it. There is not one there for the Activa 130 but the 135 is there and the 125, both will be very close to your mode.
link is
Oct 13, 2012 | Bernina Activa 130
Attachments for 140 activa
Do you mean a presser foot to sew rolled hem or shell hem edges?
If so, the Bernina website lists the accessories here:
Bernina feet 68 and 69 are rolled hem/shell, just different widths. However, I think the feet for the Activa are the new 3 digit numbered feet? I know there is the old style and new style attachment system for Bernina feet, if you look at the presser feet you got with the machine, they will have a code on the front of the foot; buy any new feet with same code format.
As to where to buy, I always start with the manufacturer/distributor in my country first. So start with, go to your country, then "contact us" page and give the local office a call. They should be able to confirm the exact foot code you need and sell it to you or direct you to a local dealer who can.
Nov 14, 2011 | Bernina Activa 140
Bernina Activa 135
Is it plugged RIGHT into the machine? Is there something caught underneath the foot pedal? might be time for a check up at your local sewing machine mechanic.
Oct 24, 2008 | Bernina Activa 130
Jun 11, 2008 | Bernina 1008
Operating manual
I also have a Bernina Activa 125 w/o a manual. (is it contagious?)!
I figured it out by experimenting:
Use a #3 foot
Hit the "0" to make a buttonhole
On the LED you can see the left vertical blinking
Start stitching your first line, stop when you want
Now press the reverse pad
Start stitching
It will stitch in reverse w/ a straight stitch only
This provides you with a "guide line" next to your first one
When you stop at the end, push the reverse pad
Start stitching
It will make 2 small zig zags and then automatically make the end of the hole (wide)
Then it starts moving up your guide line in a mini zig zag
Stop at the end, then push the reverse pad, it will make the wide end of the hole.
Now a keyhole end ... haven't tried it yet, but I think this is the other one the Activa 125 makes
Mar 01, 2008 | Bernina Activa 130
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
