Question about AudioSource soundPOP Bluetooth Speaker
Soundpop speaker will not turn on anymore - AudioSource soundPOP Bluetooth Speaker
Micro innovation speaker model# MM610D will not turn on
This Is A Huge Problem, Why Don't You Try Reconnecting The
Wires To The System And Run A Reset On It.
Good Luck,
Kevin
Aug 24, 2012 | Micro Innovations MM600D Computer Speakers
The speakers don't work at all. The blue light goes on fine, but there's no sound. They used to work fine with my iPod and iPhone, but not anymore.
Hi, Have they been turned off?
These speakers have a habit of setting their volume level to zero if the power is removed.
At the bottom of the right-hand speaker you should see some tiny volume up/down buttons.
Try pressing the up and see what happens.
May 05, 2011 | Harman Kardon Harmon Kardon SoundStick II...
My child got the remote and now my volume's not working anymore. What do I do??
Check internal/external speaker switch on back of tv. Also try turning speakers on through consumer menu using remote.
Jan 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Can you help me?
Hi
Check your speaker connections and volume adjustment knob.
If there is a power light indicator of your speaker make sure it is working so that you will know that there is power passing into your speaker.
Hope is helps..Thanks for using Fixya.
Apr 01, 2010 | AOpen MS-915 Computer Speakers
Both front speakers quit at the same time, also the turn signal does not make click noise anymore, please help!
Our speakers are rattleing, So it wont be long be fore they open.You should try another pair of speakers.And replace the signal switch.
Mar 13, 2010 | 2008 Chevrolet Cobalt
They just turn off and wont work anymore
if the amp does not turn on then try to move the ground to a better spot
Nov 26, 2009 | Car Audio & Video
These speakers are not turning on anymore even
Wow! CNet reviews seemed to like those speakers.
Ummmm make sure the power is plugged in and you are in fact getting 110vAC where it is plugged in. If you have a DC voltmeter (or multimeter) you could test for the rated DC voltage coming out of the power brick that I'm sure it uses for power.
Other than that... are they in warranty still? You might want to seek a warranty repair. Probably not worth a non warranty repair ... unless it's something simple like the DC power brick adaptor thing.
Nov 23, 2009 | Harman Kardon SoundSticks II Computer...
AudioSource soundPOP Bluetooth Speaker Logo
42 people viewed this question
Top AudioSource Audio Players & Recorders Experts
 Grubhead
Grubhead
alberto55
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
