Question about Tools & Hardware - Others
DRUM SANDER MS-3140 manual
Need a manual for DRUM SANDER MS-3140A
2 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
Manual
A quarter turn is too much. You should only turn the wheel a maximum of 1/16 turn. Sanding should be done with just the sand (not the paper) touching the workpiece. Patience is the key for drum sanders. Courser grit sandpaper will help remove material faster if that's your goal.
Jun 21, 2013 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
MODEL 11322506 MAINT. TO CHANGE DRUMS
To change drums you have to remember it is reverse thread. If the nut will not because the drum keeps turning you need to either squeeze the drum or hold the shaft near the bottom where the fins are. At least this is my experience with the Porter Cable oscillating spindle sander.
Jan 30, 2013 | Tools & Hardware - Others
Clarke plate sander vs drum for a floor that only needs
drum sander leaves chatter marks you must plate these out. belt sander is the best way to go, however it will take longer to just plate than to drum and plate. for light sanding i would start with a 60 grit on the drum, then 80, then 100. plate with 100 screen till chatter free, then final with 150 screen. this is if you intend to go to raw wood.
May 13, 2010 | Clarke Floor Sander Floor Sander Orbital...
User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Jul 20, 2009 | Tools & Hardware - Others
Need a wiring diagram for a delta drum sander
Hope that helps...
Feb 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Jan 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Tools & Hardware - Others Logo
49 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
