Question about Tools & Hardware - Others
Florabest submersible pump
Where do I find a Y slot screwdriver to dismantle a submersible water pump
    Top Expert:
  • 44,613 Answers
Go to the local tools shop and this blade will be in a collection of assorted blades that you need to remove a variety of screws.. Most use a special screw driver handle (in the assortment) or a small socket that fits the shaft.
Posted on Apr 11, 2014
Florabest submersible pump FST 1100 A1
That pump is sealed and not normal opened by the user. If you do not assemble it correctly it will become a shock hazard.
Apr 19, 2014 | HP Tools & Hardware - Others
1.5hp franklin submersible is electrifiying the water is that good
Why toy around with the possibility of electrocution when the first rule of troubleshooting submersible pump problems is to disconnect power?
Mar 24, 2013 | Franklin 2823008110 - 1.5HP Submersible...
Have a electric florabest chainsaw it wont start no power does it need water in it as there is a slot for something like oil or water but it ie empty
There will be a tank to tank chain oil to lubricate the cutting chain as it rotates around the bar, DO NOT PUT WATER IN IT .
Jun 09, 2011 | Garden
I have a submersible water pump It seems to suck ...
That is pretty much par for the course with a submersible pump. Eventually the pump will be damaged by running dry as it depends on the water to keep it cool. Can't you set it up a little on something so it won't **** dirt?
May 20, 2010 | Garden
What kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Simer Plumbing
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
No water on submersible pump
I assume this is a new instalation or you just removed and reinstalled to pump. As you have power on the load side and we assume your wiring to the pump is correst, you need to open a valve on the output side of the pum and bleed the pump. They will become air bound, Leave the valve open until it flow freeley. That should do it
Good Luck
Jan 23, 2009 | Submersible Systems 1/2HP 2WIRE...
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Tools & Hardware - Others Logo
67 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
