Question about GE 24 in. GSD2000Z Built-in Dishwasher
Dishwasher is leaving bits of old food in cups.
I have a GE PotScrubber GSD3230ZZ3WW Series GZ614920A.  Lately there have been tiny bits of food (the size of grains of sand), rice grains, and cloudy water in the glasses.  I've heard that I should clean out the strainer, but I don't knowhow to remove it.  Please let me know how I can hopefully fix this problem.
  • 1462 Answers
SOURCE: GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Posted on Apr 19, 2007
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
rylee_smith
  • 8619 Answers
SOURCE: Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Dec 11, 2009
  • 198 Answers
SOURCE: dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Posted on Jan 02, 2010
  • 21 Answers
SOURCE: when I turn on the
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Posted on Feb 19, 2011
10-yr old GE Profile dishwasher...lately there's been detergent left in the cup, and lots of items come out dirty...plastic, ceramic, etc. I've cleaned/rinsed the sprayer and filter, but it doesn't he
Check if the water is getting heated in the dishwasher. Most likely water temperature if not adeqaute will not fully use the detergent and cause dirty dishes. This could be caused by heater which is failing.
Apr 19, 2014 | GE 24 in. Profile PDW7800 Built-in...
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Mar 03, 2011 | GE Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
Not cleaning and leaving a white film on dishes
with dishwasher empty pour in two cups of white vinegar and then run the longest hottest cycle.
this will thoroughly clean the dishwasher. Then start rinsinig the dishes before u put them in and also use the potscrubber cycle all the time as this is the hottest water. J.
Jun 20, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. I have put through a dishwasher cleaning...
Hi shanandpop
I'm Harvey the Master Plumber.
Your question is: Your Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. You have put through a dishwasher cleaning solution, but find it isn't doing anything to resolve the problem?
You're still under warranty. The best advice is to use it. If it is not fixed the first time out, demand a new one from where you bought it. Sometimes they drag this out till the warranty runs out, then where will we be.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Bosch Dishwashers
Dishwasher
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
GE 24 in. GSD2000Z Built-in Dishwasher Logo
184 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
