Question about RCA HD61LPW163 61" Rear Projecection HDTV
HD61LPW163 won't start after replacing the bulb
RCA projection 61" won't start up. we changed the bulb. now it just keeps tring to light up.. but doesn't. does anyone have the schematics on this tv?
  • 3 more comments
  • idsubra May 22, 2009
    i have a HD61LPW163 manual. the only resets are in the menu. i can't find anything in the manual where it mentions reset buttons or the lamp timer reset.. could you help me find the button?
    thanks
    idsubra
  • idsubra May 23, 2009
    when the lamp went out..there was a loud pop sound. the lamp was shattered inside the bulb. he has tried taking the lamp out and back again. yes i know about the reset with the power cord. we have unpluged it numberous times..from 30 - 60 mins. it flickers when it tries to light. it also make a whirling sound (a low pitch to a high like a siren starting up. there is a light infront of the bulb that light up to a greenish color then turns off a couple of seconds later. then it repeats. he is holding down the trip switch.
    thanks
    thank you very much. since neither one of us is an electrician we took the tv to a part time repair guy. he said it could just be the bulb and the gap rate is different .. ours is a 120/1.3 the one they sent was a 1.0. i also sent all your info to the guy. i will send him this info too. in case it isn't just the bulb. we can't order another bulb until next week. the tv is a 05. and we bought it 2nd hand. so no warranty. i really appreciate the info and all your help i will send it to the part time repair guy.
    thanks
    idsubra
  • idsubra May 24, 2009
    as soon as we get the new bulb and it works or not.. i'll let you know one way or the other..what ever was wrong. thank you again.
    idsubra
  • idsubra Jul 14, 2009
    hi vortesh, i just got my tv back and as i said before i would let you know what i found out. well... after getting 1 bulb with not the same numbers on the bulb its self..i sent it back and got an original RCA bulb and when put in it started right up. the 1st bulb was a phillips not an RCA. have people check the numbers on the bulb not just what it says to use. they both were #260962 but on the bulb it is
    D:VIP-100-120/1.3 E23h they first sent a
    D:VIP-100-120/1.0 E23h and that didn't light up.
    thank you again for all your help. i hope this info helps you help others.
  • 431 Answers
Hi I am Vortash before you go into the back you may find this is just as simple as pushing the Re- set button?.. the manual is available for this set ( same Chasis and interior workings ) under HD61LPW162 at ... http://www.safemanuals.com
hope this is of help if you have any further problems just post on this page and I will be notified I will then download the service manual and talk you through any possibilities .. Regards Vortash
Posted on May 22, 2009
  • 4 more comments
  • clive pearson
    clive pearson May 22, 2009
    Just a thought check the lamp timer has been re set first .. ?
  • clive pearson
    ok will check and get back to you asap ..Regards vortash
  • clive pearson
    HI I have gone over the manual and it keeps going back to the same thing .. if you had no problems prior to the lamp going then you should have a picture .
    It does however say that if the lamp is blinking Red 5 times stops then blinks another 5 times it is still your bulb circuit at fault , it sites as the cause .. Bulb not seated properly not making correct contact in plug .. Lamp door not closed correctly and safety switch not activated try this and get back to me , oh by the way the reset lamp counter is in the menu and you can only do it when it is on ..it is not a requirement to opperate this tv as it is with most others .. Regards vortash
  • clive pearson
    Also there is a form of reset built into the set it works when you pull the mains plug out wait 30 seconds and replug it in .. Vortash
  • clive pearson
    clive pearson May 23, 2009
    AHA you should have said this before , I think you will find the problem is your ballast circuit , I didn't realize your first bulb had exploded yes they can do this just because heat cracks the glass but the can damage the ballast if this happens . I am sorry I thought you meant the previous bulb had just stopped working ( quietly lol ) I am guessing you don't have sound either then indicating the set had actually started . The plug that the bulb fits into has two wires that go back down to a square or rectangular shape box on a circuit board that is usually near the power supply and separate , this will need to be repaired .. and most likely it will have damaged components in the power supply also .. You may be best to phone an RCA service depot and ask them ( if the board is indeed separate as I say it usually is ..) the cost of a new one and if available still , and a power supply also if seperate then all it would require is a block replacement like the bulb module .. I think though phoning an engineer is your best bet .as he will at least be able to isolate which of these two circuits is at fault . however how old is this set .. and is it still under guarantee as I think I remember some RCA sets having up to a 3 year cover for electronic repairs excluding bulbs ..you should check this out .. Sorry I can't be of any more help Best of luck with this regards Vortash
  • clive pearson
    Your very welcome just wish I could do more but it is difficult trying to explain something as difficult as electronics without a drawing in front of both parties as a point of reference .. best of luck and I really would appreciate to know what was found for my future reference on this set Thanks Vortash
Is there a led replacement bulb for the rca m50wh72s? the bulb 270414 lasts only 9mos tired of spending 120$ every time to replace this
No, LED light engines are different than Mercury Vapor lamp engines. They have different power supplies and different control boards.
Mar 14, 2010 | RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW163 does not power up
ok you have defective power oscillation circuit! maybe you have shorted parts. your TV needs to diagnose to qualified technician!
Oct 26, 2007 | RCA HD61LPW163 61" Rear Projecection HDTV
How to replace the bulbs for the RCA DD61W20 61 in. Rear Projection Television?
They have some kind of Black Tar on CTR boards holding them onto neck of Tubes, you will have to remove the Front and Back of TV in order to Change out the Tubes its alot of work removing 100 screws.I have no Idea Why RCA built them to be so hard to get to!
Jan 01, 2010 | RCA D61W20 61" Rear Projection Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Tv will blink when i turn it on but no picture or sound
The number of blinks is important 4 6 10. all are requiring a service call to replace boards that have died or fused.anything from $300-$800
Aug 01, 2009 | RCA HD61LPW163 61" Rear Projecection HDTV
Rca model# hd61lpw163
hi,
while having another problem fixed the tech told us about fixing the shadow in the corner problem. check the tubes. he said when they get hot the glue around the tube melts and causes the problem. he removed the access glue and ours is all better, i hope this works for you too.
Jul 11, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
RCA HDTV
have u tried a new bulb. as the bulb aproaches the end of life is tends to do thiis i see this all the time at the shop... bulbs however not a cheap item. how old is the set has the bulb ever been changed how much is the set run average life of a bulb is 3000 to 5000 hours
Feb 15, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
No picture and no sound
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Jan 07, 2008 | RCA HD61LPW163 61" Rear Projecection HDTV
RCA HD61LPW163 61" Rear Projecection HDTV Logo
269 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
