Question about Samsung Dryers
Samsung sdc 3k 801 error code te4
Sdc3k801 error code te4
3 Suggested Answers
SOURCE: life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Posted on Jan 18, 2008
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Posted on May 13, 2008
Juki lk1903b machine is not working E7 is appers
HI
regarding JUKI LK-1903B Eror E7:
1-Machine lock error ( The main shaft of the sewing machine does not rotate due to some troubles ). please check if machine rotate smoothly by hand or not.
2-main motor problem ( AC servo motor problem ) motor part No.:401-38137.
3- check connection CN-15 / CN-17 from SDC board to main motor.
4 - problem in SDC servo board ( No output for main motor ). SDC servo board part No.:401-42267.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Apr 10, 2015 | Juki Sewing Machines
Te4 error on lg tumble dryer what is the problem and can It be fixed
High temperature thermistor open circuit 'TE4? error code . no doubt it can by a service tech
Feb 19, 2015 | LG Dryers
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
May 23, 2011 | Savin Office Equipment & Supplies
What are error codes 801 301 3D and 800 1000A on the Sony Playstation 3 console. I need help realy bad. Enyone that awnsers will have there questions awnserd. Thanks for reading.
Error 801 301 3D is due to internet connection issues.
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. ps3 , use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
And 800 1000A error means that you cannot download from the sony store. hence the connection problems from your first error.
Hope this helps you.
Correct? recommendation and vote would be aw some!
thanks.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
Hello i have two IR1024i error code #801
Have you entered dns server address and reboot, make sure password is correct
Oct 21, 2009 | Canon Office Equipment & Supplies
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
Life style error codes 801 & 802
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
Bose Lifestyle 48 Error code 801
We had this problem. I called Bose, and they reported that the 801 error is a hard drive problem. The unit started squealing while I was on the phone to support, and the guy heard it. Said the hard drive was failing.
$200 to ship the unit to Bose to replace the drive. Wish they had a secret warantee for what seems like a common problem.
Oct 01, 2007 | Bose Lifestyle 48 System
Dryers Logo
367 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
