Question about Xerox Phaser 8500/DN Printer
Xerox 8860 stuck in inialize
Drum doesnt heat up. No error messages displayed. Could this be a
power supply problem
    President:
  • 2,072 Answers
Sounds more like an NVRAM issue.
Posted on May 22, 2009
I have a phaser 8860 that has stopped and gives a printer error of 09,035.43:65927
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8!9!6!9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Feb 17, 2015 | Xerox Phaser 8860/PP Color Laser Printer...
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Error 04,018 48 xerox phaser 8860
The printhead temperature is too low.
Check the air temperature (the room should not be cold)
Test the heaters in Service Diagnostics Monitor. If the heaters function properly, then replace the Electronics Module...if they don't, then it could be a bad printhead, drum assembly, drum heater relay board, or drum temperature sensor.
Jan 29, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox Phaser 8860 error code 04, 025,.46:0?
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
How to keep Phaser 8860MFP from printer the cleaning Page
Am using Phaser 8860 its a good printer but the problem am facing is that it is failing to clean the head or drum. The first testing page gets stuck on the head or drum. The drum is always dirt with colours of the first page. Kindly heal
May 07, 2012 | Xerox Phaser 8500N Printer
Error 08,035.42:7417 after power loss. on 8650 phazer
my xerox printer phaser 8860 is stop printing. message show, 08,035.42: 138484. Is this fixable
Apr 05, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
Xerox phaser 8860
This unit has a common situation that requires parts and 2-3 hours of labor. This error points to a bad process motor 127K53240
These generally go bad with 2 camshafts 020K14800 and 008K02160
Whit
Item, Inc.
Jul 10, 2009 | Xerox Phaser 8560DN Printer
Xerox copier
J messages on Xerox machines always refer to toner or drum.Is the toner out , you could give it a shake (might be a good idea to go outside!) Sometimes it will run out without displaying a message(Pyramid of dots for out of toner) Drum end of life usually comes up with a crossed circle or similar .If all OK you could have a blocked toner supply auger or lumps caused by storing toner in sunlight, both would require the toner system being vacuumed out.
Nov 26, 2007 | Kyocera RI-3530 Black and White Copier
Xerox Phaser  8500/DN Printer Logo
299 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
