Question about Royal 160MX Shredder
Gears are clogged - Royal 160MX Shredder
How far can i travel in 97 park avenue when gas light come on?
less than ten miles
running on dregs from the petrol tank
clogs fuel filter and can damage pump even injectors
Jan 15, 2017 | Cars & Trucks
My paper shredder will not shred or grab the paper?
If the motor is spinning, it's probable broken teeth on the drive gear. The drive gears are usually the first thing to break on a shredder.
If the motor doesn't spin. The paper may be clogged in the grinder claws. You may have to turn the shredder over (after you remove the power cable from the wall outlet). Then remove the papers from underneath.
Hope this helps.
Feb 28, 2015 | Shredder Office Equipment & Supplies
Mondeo 2002 1.8 petrol when giving the car some gas to overtake it does not want to go all out in all the gears
This normal Cause is one of a few things...
Clogged Fuel Filter
Clogged Air Filter
Clogged Cat
Apr 08, 2013 | 2005 Ford Mondeo 1.8
Toyota Vista SV50 model / year 1999: I have used Dextron type 2 automatic fluid in the auto transmission. Could this be the problem for auto gears sticking in same gear too long when car is started in...
Hi, since you use a dextron type 2 automatic fluid then it is not cause of the sticking gear. Rather it should be as a result of a clogged transmission filter. A clogged transmission filtercan cause problems with changing gears because it will not allow the fluid to pass through the valve body or valve solenoids at the proper pressure. Without pressure, the plates won't move properly and you won't be able to easily change gears. This can be symptomatic either by itself or along with burnt or worn out transmission fluid, and both should generally be replaced at the same time, rather than just replacing one or the other.
Jul 22, 2011 | Toyota Camry Cars & Trucks
Car is sluggish in all gears been told variable veins in turbo clogged,can i clean myself?
You can try running product called SeaFoam through with tank of fuel - but that's a long shot. When turbos start clogging up - it's like concrete. They get baked on and it's really tough without proper tools to remove without damaging.
Mar 31, 2011 | Saab 9 3 Cars & Trucks
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
I followed the instructions above and found that neither brush turned. when no brushes are in and the vacum is running the gears are not turning either when i look inside the unit
You need to clean the gears hidden in the housing itself. they have become clogged with hair etc and wont turn.
This will require you to remove the housing.
Feb 23, 2010 | iRobot Roomba 530 Robotic Vacuum
Loss of power on and off through gears
check throttle position, O2 sensor for air/fuel mixture, fuel injectors for clog, spark plugs and coils.
Oct 03, 2009 | Mitsubishi Pickup Cars & Trucks
Door tray will not open and screen reads loading but no disc is in
sounds like your system needs maintenance cleaning dust or some debry has been clogging tray gears have profesional clean out and regrease gears for proper use again
Jun 01, 2008 | Samsung HT-DS610 System
Royal 160MX Shredder Logo
27 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
