open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Possible that the quality of the bulb is questionable. So please make sure that you buy one from the authorized dealer or one which is given a warranty for working hours /time.
The ambient temperature in the room is to high. Try lowering the room temperature. If that doesn't work get a small fan and place it near the projector to provide extra cooling. The projector is running border line on high temperature and just needs a little extra cooling.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
NEVER BEFORE OFFER ON DELL DLP PROJECTOR 2400MP
3000 Lumens Brightness, XGA Resolution, 2100:1 Contrast Ratio
Sony, Sharp, Hitachi, Toshiba, NEC, Benq, Acer, Epson All Are Above Rs 60000/-
Great Offer from Dell Pay Rs 42000/- And You Get
Two Years Warranty +
One Additional Lamp Worth Rs 15000/- +
One Projection Screen 6 by 8 with Tripod Stand worth Rs 7000/- Absolutely Free.
Limited Period Offer.
Please contact at
It gear. In Shop no 14, Sakhai plaza, Nr. Kothrud Tel. Exchange, Kothrud, Pune, India. Land mark- Shree Shivaji Statue. Telephone -020-66021475, Hand Phone - 9850557001. Contact person- Ketan
www.itgear.in
Take out the lamp and check for any marks on the inside ( shaft ) of the lamp. If there is marks or discolouration on it then you can be 100% sure it is the lamp.
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the projector off, wait at least 30 seconds, then turn it back on.
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
