WILL NOT PICK UP HARD DRIVE OR DVD
It will not pick up the hard drive or dvd it show no hard drive installed, I bought another hard drive and the same problem, If I use a usb dvd it will start to load windows and than I get the message no hard drive found, I have gone into bios and set it at default, changed it to only dvd and hard drive, same problem, I took out the cmos battery for about 4 hours and the same no hard drive found....can you help thanks g5114
  • 1 more comment
  • g5114 May 22, 2009
    yes, the hard drive was western dig, the laptop is a hp pavillion zd8000
  • Wilhelm May 11, 2010
    have you tried a different cable?
  • Frank Zhang
    Frank Zhang May 11, 2010
    new one is same brand model?
  • 696 Answers
Look through your bios for a setting called QuickPost/QuickBoot/QuietPost....
Disable this feature then save and exit the bios, when you restart you should see the long version of the bootup screen, generally if it is turned on the laptop will not see or accept hardware changes until you disable the option.
If it finds your drives you can turn the feature back on for quicker booting on the next bootup. If it still doesn't see your drives I would suspect a fault on the motherboard.
Let us know if this works, if not we'll try a few other suggestions.
Hope this helps FixYa,
Chris
Posted on May 24, 2009
My hitachi 1tb xl1000 drive wont read my files and is saying that the drive is not formatted. What is this?
It means that there is no operating system installed on your hard drive and so it will not work until you add one. Buy a windows xp disk or an operating system that you wish to use and put the disk in the cd/dvd rom. Reboot the pc to get it to pick up on the disk in the drive and then follow the prompts to install an operating system.
Mar 21, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Bought a used IBM ThinkCentre M52 8215-VAN S/N LK71288 for $5.00. Needed memory and hard drive. Installed memory. Don't have harness for hard drive. Not sure where to plug hard drive in. Has optical...
if you have any discs in the dvd remove them... it should boot to the hard drive when it doesn't find anything in the dvd. if you need to install an operating system put that disc in the dvd and boot from it. during the installation it will start to run off the hard drive. when you are done installing remove the installation disc.
Sep 30, 2010 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
I have a dell latitude L400 which has external DVD Rom. I have bought new hard drive and traing to install new window but the sistem sais that The operating sistem is not found. F2 and F12 kis are not...
With a new hard drive you have to first format and install an operating system before it will work. Insert the hard Drive and connect up the DVD, set system BIOS to Boot from removable media IE: The DVD, and insert a Windows setup CD/DVD in the DVD drive, boot of that DVD, and proceed with the install following the instructions. That will install a Windows operating system.
Feb 18, 2010 | Computers & Internet
My dvd and cd rom does not pick up dvd but only cd's
Is it really a DVD drive? DVD drives can pick both with ease but a CD drive cannot pick DVD's.
Nov 29, 2009 | Acer TravelMate 512DX Notebook
I bought a external hard drive and want to backup my dvd's on it. What do I need in order to do this?
All you need is a good working DVD ROM and a 2.0 usb port.
Plug in your hard drive to the usb port.
It should install and be ready to use in a few minutes.
Insert your DVD's
Open My Computer and open your dvd disk (right click on the icon and choose open)
Open My Computer again but this time open your newly inserted hard drive (there will be an icon naming the drive)
Now, just use copy / paste from the dvd to the hard drive (you may have to create folders on the hdd to keep it organized)
Hope this helps.
Nov 02, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
My laptop does not pick up the device in Drive e: works OK for the memory stick.
if e: is cd\dvd the clean the laser head of drive otherwise the laser gone bad need replacement.
Sep 16, 2009 | Iomega HDD External Desktop (32660) 80 GB...
CD does not work
The most likely cause of all is that the laser has gone in the drive its self,
you can pick up a dvd-rw on ebay for £10-£15 including postage on ebay,
try a new cd drive and it should work, the other thing could be that the motherboard cd drive connector has gone, try linking your hard drive and cd drive together on 1 cable (through the hard drive socket on motherboard)
Rate me!
May 26, 2009 | Dell Dimension 2400 PC Desktop
DVDs won't play on my hard drive
Your drive has had it then matey,
you can pick cheap ones up on ebay now, you can even go to ebuyer.co.uk and pic up a blu ray drive!
Feb 16, 2009 | Gateway Computers & Internet
Hard Drive Issue
you can access the bios settings at the first boot screen here you have to go to you boot priority and make the dvd Rom drive you number 1 in the list, save and exit bios insert the xp professional disc and re-install window. during this process do not reair you copy of xp home just install the xp professional it will automatically detect and delete the old xp home files without deleting any of your data. But DO NOT formatt otherwise you will lose your data. lease the file system as is. the only catch with this method is that due to the xp home registries being deleted along with it. most of the software which was installed on xp home will be there but not work you will have to re install it.
May 31, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
