Question about Dishwashers
Cda dishwasher cw496 The panel lights up to select a wash cycle but the start button doesn't work
gwshaw71
  • 83 Answers
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
  • 171 Answers
SOURCE: dishwasher powers up when switched
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
SOURCE: CDA dishwasher (model number CW496) , stops
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Posted on Jan 08, 2010
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
My cda cw496 dishwasher beeps in the middle of the cycle and then water leaks from the bottom. any suggestions?
The problem could well the plumbing past the machine... Are any of your other drains in the kitchen slow? A little snaking of the drain lines may be in order.
Jan 02, 2015 | CDA Dishwashers
Stuck on washing cycle
Thank you for your post, Patrick Chow!
From my understanding your Frigidaire dishwasher is getting stuck in the washing cycle. Sounds like you may have a possible issue with a sensor or control panel. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for approximately ten minutes. If you continue to experience problems with you dishwasher not cycling I would recommend reaching out to a technician for a diagnosis to be completed. The technician would be able to pinpoint the cause of the failure and complete repairs. Hope this is helpful. -Matt
Nov 17, 2014 | Frigidaire Washing Machines
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Press start it runs for about 20 seconds then starts beeping with no water in the dishwasher cda cw496
have you checked the water inlet hose behind the machine to make sure its not kinked??
Jan 12, 2011 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
Sep 21, 2009 | Dishwashers
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
15 people viewed this question
Top Dishwashers Experts
