Question about Garden
Greenfield drive belt diagram - Garden
3 Suggested Answers
SOURCE: wiring diagram for a E2000 greenfield, OHV Vanguard motor
Hi...How did you go? Did you end up getting one? I need the same if you can helkp me out. Cheers Glen
Posted on Dec 05, 2009
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
Greenfield Ride on Mower need to increase tension on drive belts
As a rule there is 2 ways.
1 is a spring loaded idler pulley and the other is to loosen the motor and pull it back.
Depends on the age.
May 14, 2017 | Garden
My Greenfield 12-30 mower constantly drops the Drive Belt. How do I correct this?
First make sure that you have the correct size belt.
Then make sure the belt you are using is not stretched or worn out. Check all pulleys and make sure they are not worn and that they are in alignment. Finally make sure that all the idler springs are in place. It is wither an alignment issue or a belt tension issue
Feb 02, 2015 | Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
I need a diagrahm of a belt drive greenfield ride on mower
Nov 10, 2010 | Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Wiring diagram for a E2000 greenfield, OHV Vanguard motor
Mar 17, 2009 | Briggs & Stratton Garden
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
