Question about Spiderlegs Hand Crafted Dining Folding Table - Red Mahogany - CD3030-RM
Label struck to table
Label struck
CAN I RETURN A PACKAGE YOU SENT BY MISTAKE,ALSO SENT WRONG MAILING LABEL? SENT LABEL TO RETURN IDEM I ORDERED & DIDN'T GET?
SADLY Frank we are not where you ordered anything from nor do we know who that was .check what you are doing and try the correct website .
Nov 21, 2015 | Computers & Internet
Label print problem making in MS word
You need to set up the paper print size for the Cannon. It may be a different print height and width.
Feb 27, 2014 | Canon LASER SHOT LBP-2900 Printer
Table Caption Problems
Select the first table.
Right-click on it and choose: Insert Caption
In the Caption dialogue, Click on New Label...
Type in "CS - " (without the quotes)
Click OK
The caption should appear beneath the first table.
Select the second table.
The dialog should contain the same caption as the first, except the number will be incremented by one.
Repeat to the end of your tables.
Format captions as desired.
Nov 01, 2012 | Microsoft Word 2010
Do billiard balls wear down in time?
Yes. In one year period of daily play all the balls in a set will be smaller than the allowed minimum in the
equipment specs. The cue ball wears fastest, as it is struck by the tip and skids on the cloth on every shot. It is also sent off the table more often, as well.
Jul 31, 2012 | Sport & Outdoor - Others
What tonage is the a/c we have? Goodman , Model # PHJ063-10? I ned this so I can get it to my insurance company, and buy a new on as Lighting struck this one.
Odds are it is a 5 ton heat pump system. The PHJ060-1 is a common model number, maybe the lighting distorted the label a little making it hard to read. Might have been PHJ060-1D?
Aug 22, 2011 | Goodman CKL36AR36 Air Conditioner
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
DAO in vb
Nice try. Find an upper-class student to give you one-on-one tutoring with your homework.
Apr 16, 2009 | Computers & Internet
Labels how to print
In your Word processing program (Word, Wordperfect, Writer, etc...) there should be a label module usually found in the Tools menu. From there you can set the size of your label as well as the contents or you can have the program generate a page with a table set to fit your label paper.
Oct 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper feed to far for labels
You should adjust the shutter as well to the size of the paper. Another thing is you can manually select the paper type under the printer settings. Go to Printers and Faxes > Properties of your default printer and manually select the paper type.
Sep 30, 2008 | Epson TM-L60II Thermal Printer
Printing labels
You have to feed the labels through the manual feeder.
Aug 23, 2008 | Brother HL 2140 Laser Printer
Spiderlegs Hand Crafted Dining Folding Table - Red Mahogany - CD3030-RM Logo
63 people viewed this question
Top Spiderlegs Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Spiderlegs Rock and Ice Climbing Expert? Answer questions, earn points and help others
