Question about Microwave Ovens
Battery charger manual 315.CH2020 - Microwave Ovens
Sharp r884. Will there be enough space for safety in my housing unit for it which is 570 MM. Wide, 315 MM high, 580 MM deep.
Dimensions (WxHxD): 52x30.9x48.8 cm - Should fit in your space, however ... this doesn't leave much room for air flow unless there are vents in the back. There must be somewhere for the hot air to go.
Jul 25, 2016 | Sharp Microwave Ovens
My Samsung oven fe-r300sb has problem
It must be broken. Buy a new one. Send the old one to me, I'll make a welder or battery charger out of it.
Feb 23, 2015 | Samsung Microwave Ovens
What is wrong with the microwave if the food doesn't get hot?
make sure your power level hasn't been set down. You should be able to set it with a button on the panel.
Feb 18, 2015 | GE Profile Spacemaker PVM2070DMBB 2.0 cu....
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave┬«
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
I just received a WP Bistro pressure cooker and my grand son has hidden the instruction manual. Can I up0load a copy please. I haved a need to use this item Saturday. Thank you
Go to this link.... scroll down to pressure cookers select the first one on the menu BPCR0005 and click view (Cookies enabled or temp allow popups)
http://www.wpcookware.com/manuals.asp
Your 32 page manual is 315 kb.
Thanks for choosing FixYa.
Kelly
Jul 01, 2011 | Microwave Ovens
I have a Shark Clean Sweeper and need to replace the 7.2v charger. Where can I find this.....I'm running into blank walls.
Actually, the charger for this 7.2 volt machine probably puts out nearly 9 volts to push the voltage into the battery. It shouldn't hurt the battery to use a 9 volt charger as long as the connectors match up. There are a lot of devices out there now that use 9 volts, so it shouldn't be too hard to find one that would match up with the connector on your sweeper. All the charger/transformers tell the input they use and the amount of voltage they put out.
Mar 23, 2011 | Microwave Ovens
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Instruction manual
Your specific manual is here.
You can find Sanyo UK owner's manuals here
Sep 13, 2008 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
