Question about Jazz Video Cameras
Jazz hdv146 isnt working
Wont turn on unless plugged in doesn't show screen and doesn't well do anything except show usb symbol and show the mode and beep
seventonine
  • 72 Answers
SOURCE: boot_c_03.05.00r_mpap
http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS
update your firmware.
Posted on Feb 16, 2008
  • 13 Answers
SOURCE: Motorola Flash Mode
Can you hold down the center nav key and power up the unit? Then select Yes and perform a Master Reset on the unit. This should fix the file system possibly correcting the issue.
Is this a Q, Q9m, Q9c, or Q9h? Who is the carrier?
Posted on Apr 11, 2008
SOURCE: motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Posted on Aug 05, 2008
mneilsen2084
  • 342 Answers
SOURCE: frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on May 06, 2009
Yogger
  • 117 Answers
SOURCE: my symbol mc50 scanner wont
it is possible that if you changed the battery you forfot to move the slide button next to the battery to the correct position. It often happens to me :-) Please check it, its on the right top corner of the battery, you should not see the red marking, if there is the correct position.
Posted on Dec 02, 2010
I need to know what kind of charge a jazz hdv146 video recorder take's
The optimum charging time will be specified in the manual
Dec 10, 2016 | Jazz Cameras
Jazz hdv146
if you have all the paperwork and reciept take the goofy thing back..
Feb 06, 2014 | Video Cameras
Do i need a specific type of sd caed for my camera to work
Are you sure you have an SD card, 2GB or smaller? The HDV146 will not work with higher-capacity SDHC cards.
Jan 26, 2013 | Jazz HDV146 Silver 8MP HD Camcorder, 2.0"...
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
My phone died last night. plugged it, showed the charging symbol. after about ten-fifteen minutes i tried turning it on. now it refuses to turn on. just shows a screen with a USB symbol on it.
Try plugging it back in and turning the phone on while it is plugged in. If that doesn't work, you can try removing the battery and turning on the phone, but I'm not sure what that might do.
Jul 19, 2011 | Cell Phones
Samsung yp t9j Media Player (2 GB)
This mp3 player and many others do not play or do anything on screen besides charge WHILE it is connected to the computer. You can transfer songs to the player while it is connected to the PC. After it is disconnected, then you can play songs.
Nov 09, 2008 | Samsung Yepp YP-T9 Digital Media Player
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Sansa c250 not working at all!
2 Suggestions: 1) It may be that the battery isnt charged, let the unit charge fully 2) If that doesnt work, its probably time to send the unit back to sandisk
Jul 23, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Video Cameras Logo
Top Jazz Video Cameras Experts
mohamed salim shaikh
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
