Question about Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer
My Alienware M9700 starts up but turns off before Windows can start
I've replaced the Motherboard, it still turns off before the Alienhead startup screen.
    Habit-Forming:
  • 29 Answers
Sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Posted on Jul 25, 2014
4 Suggested Answers
SOURCE: My computer has been running slowly. i have the
Need to know what motherboard is installed so i can tell you how to set/check your Bios settings that may have reset to default after format.RICHARDM69
Posted on May 03, 2009
Fixitman909
  • 430 Answers
SOURCE: Mystery blue screen won't let me log on my computer!
IF U CAN GO INTO BIOS GO IN BIOS AND CHANGE FIRST BOOT ORDER TO CD ROM THEN PLACE XP CD IN CD ROM AND RESTART PC. AND REINSTALL WINDOWS..........
Posted on Jun 09, 2009
  • 570 Answers
SOURCE: How can I adjust the screen wobble on a alienware
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
Posted on May 29, 2010
No audio output device installed alienware m18x
That is a sound card driver issue the drivers need to be uninstalled and reinstalled and if that doesn't work replace the board itself that is either software or hardware that is causing the fault
Apr 11, 2013 | Alienware M18x 18.4" Laptop Computer
Alienware m9700 runs slow
operation system? memeory capacity? hard drive type? overheating?
Nov 15, 2012 | Dell Alienware Computers & Internet
Alienware m9700 running slow and hot
First , are the fan and vents clean? Are there many programs running at the same time? Is there sufficent air flow? You might want to buy a laptop cooler with as many fans as you can get. Do you have CCLEANER found here:http://www.filehippo.com/download_ccleaner/ OR MALWAREBYTES :http://www.filehippo.com/download_malwarebytes_anti_malware/ If you don't use these programs give them a try they are free. Malwarebytes has many useful tools. That's a good place to start.
Nov 15, 2012 | Alienware PC Systems Computers & Internet
On my Aurora m9700, the power button stays orange and does not turn off system. Soft-off causes a reboot which goes through post normally until it reaches the boot point, then gives a toe-up beep and the...
Sounds like a Memory issue. It defiantly a conflict somewhere. I would start with the memory. If you have two sticks installed, then remove one. If it does the samething, re install and then remove the other one.
Feb 11, 2011 | Alienware PC Systems Alienware Aurora High...
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Jun 09, 2009 | Alienware PC Systems Alienware Aurora High...
My computer has been running slowly. i have the alienware m9700 and i decided to do a reformat of my computer. I tried reinstalling windows and it gets to do it then restarts to complete the installation...
mdg941 shut down wait 1 minute, start up and tap f11 repeatedly until you get a recovery screen. there you will have 2 options read them before your decision,,if you want your computer like brand new with evrything from store. then use the 2nd choice, it will take 30=45 minutes to run but it will be as good as new. do not do anything to it once it starts. when it finishes it will ask you a few set up questions, do them then let it be it will reboot itself and your on your way..let me know how you make out.
May 02, 2009 | Alienware PC Systems Alienware Aurora High...
Need a A306 or A307 for my Alienwars M9700
The drivers can be found at; http://aliendl.alienware.com/mobile/m9750/m9750_TV-Tuner_A307_XP_Vista_1.12.0.43.zip And if it's actually getting the card that you're meaning, you can purchase it direct from Alienware (I don't believe they supply them seperately anymore, but they'll happily supply one if you give them a call)
May 25, 2008 | Computers & Internet
Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer  Logo
63 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Larry Chandler
Jerry
Jerry
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
