Question about Air Hogs Toys
Half of the stabilizer on my air hogs drop strike broke off and we melted one end of it to try nd stick it back on
4 Suggested Answers
  • 30 Answers
SOURCE: air hogs rotor - pulled wires
first just shove the wire back in and try to wiggle the motor back in and it should appear to be untampered and if you still have the box there is a number on the back, you just tell them the rear motor didnt work and they will send you a new one or you can put it back in the box and take it to wherever you bought it and tell them the same thing and then theyll give you a new one if you cant find the number here it is: 1-800-622-8339
Posted on Dec 30, 2008
SOURCE: can i find a replacement prop for my kids air hog storm launcher
i called spin master and thy dont make them anymore
Posted on Dec 05, 2009
  • 7 Answers
SOURCE: i just bought an air
Found it on ebay...
http://cgi.ebay.com/Stabilizer-Blade-Balance-Bar-air-hog-Reflex-Helix-Heli-/250711651055?pt=Radio_Control_Parts_Accessories&hash=item3a5f9432ef#ht_920wt_1141
Posted on Mar 01, 2011
Balance blade rotor broke
You can get a new balance beam on Ebay for a few pounds just search Air hog. Just check the linkages are ok before you order so you can buy them as well if needed. They are actually called a " Flybar"
HTH
Jan 03, 2014 | Air Hogs Hover Assault Vehicle
Tip
How to make the Spinmaster Air Hogs Moto Frenzy R/c Stunt Bike work.
If the bike isnt working properly, like short driving time and wobbly steering. lay it on the side with the screws pointing up, unscrew the 4 philips screws, the body is glued together so be careful, with a small flat screwdriver or a knife, bend the body apart along the crack going through the middle. Be extra careful in the lower front part because this is were the battery is placed. When the body halfes are separated, lay the half containing the elecronics and motors so you can axess the parts. Remove all dust and hair and othe forein matters. Take the rear wheel off and slide the tire off.With a small screwdriver press the three locking notches that holds the wheel togeather and separate the halfes. put a small amount of lubrication oil (thin oil) on the gyro axel inside the wheel and on the drive gear and spinn the gyro wheel so the oil gets in to the "bearings".Press the drive gear so it sits tighter towards the wheel (not too tight, it has to spin freely. Put the other half of the rear wheel back and spin the gyro wheel with your fingers as fast as you can. it should balance itself on a flat surface for atleast 5 - 10 seconds. if not put some more oil on the shaft, and try again. When finished dry of excessive oil and put the tire back. Take the dual gear that's in front of the rear wheel off. there is a small shim between this gear and the one that's still on the shaft. put some oil on the shaft and spin the shim and remaining gear so the oil lubricates the movement. put the dual gear back.Remove the wheelie gear ( the one with a stick lying under the bike) put a drop of oil on the gear axel that's underneath the wheelie gear. Spin all the gears so the oil can get inside and then remove the excessive oil with a tissue or something like that.The wheelie gear has a spring mounted on the backside, be sure to get this back right (the small ring of the spring shoul fit on a plastic pin in the body and the bigger ring on the cnter of the wheelie gear), and then put the wheelie gear back so it sits centered and conected to the second gear.Put the rear wheel back.Take the other body half and put a drop of oil on the gear shaft thats still in there, spin the gear etc.Put the halfes togeaher, be careful so you get all the axels and pins right and no wires between the halfes. squeese the halfes togeather and screw the 4 philips screws back. Put the driver back and charge the battery. Try it!!!
on Jan 13, 2015 | Spinmaster Air Hogs Moto Frenzy R/c Stunt...
Support@airhogs.com
I need the stabilizer for the air hog Razor on the first lift it hit the ceiling and broke in two . so where can
i buy this part
Nov 02, 2012 | Toys
We broke the stabilizer of our air hog havoc heli. Where can we get replacement part?
I replaced a broken stabilizer successfully with a regular paper staple (like the kind in a red Swingline stapler). It's the right length! I punched the staple through the stapler to bend the ends, rounded them a bit with needle-nose pliers to fit over the stabilizer pegs, then used the pliers to tighten the loops. (I got a couple of Air Hogs recently at a garage sale, but one was missing a stabilizer. Excited that it works now!)
Apr 09, 2012 | Air Hogs Havoc Heli Helicopters
I just bought an air hog havoc stinger and the stabilizer broke. where can i get a replacement part? please help!
Found it on ebay...
Mar 01, 2011 | Toys
Air hogs rotor - pulled wires
Dec 26, 2008 | Spinmaster Air Hogs Battling Havoc R/C...
Broken screen
ii Broke Miine Nd JUstt Putt THuu Screen Bakk iin Place Nd iiT Was Owkaii ... x
Aug 09, 2008 | Sony Ericsson S500i Phone
Air Hog Stabilizer Propeller snapped
cut off the other side mine flies just fine now
Dec 25, 2007 | GPS
Lagging problem
raheell, I enjoy building and modding. But I would never try to game with only 512 meg of memory. 1gig would be my low end and 2 gig would be average. Just looking at the Game specs and different Counter Strike and Half Life pages. I would check that DDR1 memory and the drivers on your 7200gs. But my bet is lack of memory or the memory is just not the quality for long hard work. Though it is cosair my favorite memory. Does it have heat spreaders on the sticks or stick? Have you investigated the 7200gs. Check out the Counter Strike and Half Life forums. I found some interesting facts. I also would post to CPU (Computer Power User Magazines site) They are the high performance place to go for hardware problems... Just some thoughts... PCdok
Oct 20, 2007 | ASUS A8V-VM Motherboard
Toys Logo
210 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
